I replaced
1/Bearing Ledge Exhaust
2/Bearing Ledge Intake
3/Camshaft position sensors
4/Solenoid valve 2 times
5/vanos
6/ Impulse sending wheel
7/ checked timing many times
still getting code :
003100:
boost pressure control deactivation
2A82:
vanos intake
sometimes
2a87:
exhaust vanos, Mechanism
if car ignition is one , no faults of the above
checked and replaced engine oil ( 5w40 )
checked everything in the bmw Service bulletin
car is :
135i E82
3JE pistons 84.5
Manley H-beam rods
ported head stage 3
new oil pumps
new water pump
BMS BEF
5/vanos
003100:
2A82:
vanos intake
sometimes
2a87:
car is :
135i E82
3JE pistons 84.5
Manley H-beam rods
ported head stage 3
new oil pumps
new water pump
BMS BEF
