Vanos codes, please help
DXB
I replaced
1/Bearing Ledge Exhaust
2/Bearing Ledge Intake
3/Camshaft position sensors
4/Solenoid valve 2 times
5/vanos
6/ Impulse sending wheel
7/ checked timing many times
still getting code :
003100:
boost pressure control deactivation
2A82:
vanos intake
sometimes
2a87:
exhaust vanos, Mechanism
if car ignition is one , no faults of the above
checked and replaced engine oil ( 5w40 )
checked everything in the bmw Service bulletin
car is :
135i E82
3JE pistons 84.5
Manley H-beam rods
ported head stage 3
new oil pumps
new water pump
BMS BEF
I replaced
5/vanos
003100:
2A82:
vanos intake
sometimes
2a87:
car is :
135i E82
3JE pistons 84.5
Manley H-beam rods
ported head stage 3
new oil pumps
new water pump
BMS BEF
I assume that you replaced the metal ring gasket on the bearing ledge with the non-metal ring gasket? Or that the new bearing ledge came with new non-metal ring gaskets on the end? And you replace both your vanos solenoids?
FaintOverBoost
East TN
01 330ci, 08 535i, 08 535xi
I replaced
5/vanos
003100:
2A82:
vanos intake
sometimes
2a87:
car is :
135i E82
3JE pistons 84.5
Manley H-beam rods
ported head stage 3
new oil pumps
new water pump
BMS BEF
What happened leading up to this? Have you cleaned the Vanos Filters? If yes, double check you have the vanos solenoids plugged in correctly, and not reversed... if that has been checked triple check timing.
DXB
Hey guys,
Regarding the above issue,
my issue is a mixed Solenoid connection, I upload a picture.
after troubleshooting all of the list above you will be remaining with mixed Solenoid connection.
