Unlocking the E9X backup camera!
Also, did you test the camera to make sure it engages when you go into reverse?
It was actually in the mail today. Now the only thing I need is motivation. My xcarlink came in the mail also.
jonbloom
Grand Rapids, MI
jon.tw
I tested the module by connecting a DVD player (lol) to it and shifting into reverse. It worked.
I got the new camera in Tuesday, and installed it last night. Oddly enough, the new camera had a longer cable, which meant I didn't have to fish the thick molded plastic circuit board thing through the flex tube, just the camera connector. Much easier this time around.
My module doesn't seem to be sending out 12v out of the white wire to be connected to the camera, so I just tapped into the red 12v line that goes into the module and that works fine. I'm not worried about it killing my battery, as I confirmed that the car shuts off power about 20 minutes after you take the key out.
Here's a pic of the screen:
You'll notice some distortion in the feed. I can only assume that that's the camera trying to compensate for the wide angle. Oh well.
Interesting. What do you mean by thick molded plastic circuit board?
Here is a photo of what I got. Does yours look like this:
So I went out to start working on the camera install and this is my problem since I'm e93. The wiring loom comes down to a plastic connector which is too skinny.
Andy
77
27
California
Is there any kind of lag on turning on the camera when putting the car in reverse?
I've heard that these tend to do it a lot.
This is due to not twisting the wires enough apparently. I went with a different method, if you want to use this emulator box(Its much more cost effective than my way) than I have the box and the plug and play play harness to splice into for sale.
slow_henry
42
nj
I did this diy yesterday all works perfect camera install amd coding went in smooth as to the camera menue is there a way to program/activate guidelines on the car?, im aware the camera
comes with a green wire that your supposed to cut to activate the guidelines from the camera but instead of doing this I woukd like to activate the ones from the car (hopefully they'll move as steering wheel moves) anyone knows if it' possible
Yes, I've read about a way to do this but its expensive and if my memory serves me correctly it involves buying some euro 5 series modules that do not belong to this car. Dynamic lines are not worth the hassle, you'd be better of buying an xcalink which does this.
Reactions: slow_henry
slow_henry
42
nj
oh ok if it' a matter of hardware then yeah not worth it, just thought there would be a small chance that coding would bring up the options
slow_henry
42
nj
not really I ready that could happen when there are poor conections just make sure all the wires are nicely joint
How did the coding match up to the information given in the guide? I never got a chance to test it. Also what car do you have?
slow_henry
42
nj
I took a screen shot from a post on e90 I believe is the same, it worked perfect, at first it didn't but only because I mest up miscounted the pins so I had to take it apart again lol
Aaron
544
201
Colorado
Silver 2013 335is 6MT
Does the screenshot show where reverse is on my shifter?
Because that forum literally had a post asking that.
