Turner vacuum canister relocation kit review.
I installed the Turner vacuum canister relocation kit last night and it fits alright. It does the job. If you are going to install a relocation inlets let kit you will need this vacuum canister relocate if you plan to keep the vacuum canisters. I have the steel canisters from stett and it was a very close fit. I thought it wasn't going to work but found that the steel canisters are not identical sizes so I just rearranged the mount order on the bracket and it finally worked.
Is this a shorter run of vac line?
Same at some parts like solenoid to original location hoses were connecter to the two stock hard plasic hoses draping over the engine. New hoses added to the other side to reconnect to top of canisters. New line was added to vacuum assist steering tube and connected to bottom of canisters. Vacuum assist steering nipples were rotated towars the canister direction before attaching new lines.
Reactions: ShocknAwe
AshwinLB
39
26
Toronto, Canada
2008 135i 6MT "Narrowbody 1M"
I can confirm that this Turner bracket fits BMS metal vacuum canisters with slight modifications to the flat bracket part of the canister
