Since my car is up on jackstands I figured I'd upgrade my transmission cooler. Previously I had been running a converted PPKv2 radiator as a cooler. I do not recommend it because you'll experience runaway temps, that core is no match for the stock system. I've dealt with it for a long time because I have not driven my car much but now I've decided to take some action.
I started by sourcing a 'Small' dual pass cooler from Mishimoto then upgraded to the Large then went to a Setrab 72 row but in the end I decided to go back to an ebay dual pass that is virtually identical to the Mishimoto unit. I bought these coolers on sale in December 2018 and they have just sat in my garage and upon looking just now, it appears they are half off the half-off price I paid before, just under $60 a pop:
This cooler isn't a world beater but it does fit the given space with convenient side outlets unlike pretty much any other cooler I could find. Since this is not a race car and I don't like the look of deleted ducting, my constraint was an oem fitment and that meant retaining the fog lights, brake ducts and headlight washers. Ideally, I'd be able to retrofit my existing PPK duct with this new setup.
After testing fitment(and waiting a year) I pulled off the frame rail support bracket and hammered it flat. The OEM bracket comes in at an odd angle and means the task of bending metal to fit had become no longer a DIY at home sort of job. Since I don't have a welder I would have to stick to more rudimentary means to make this work.
This is what the bracket looks like before:
Used a dremel to cut off the welded bolts:
Take a heavy hammer and flatten it out to make a nice mounting surface. This picture below was not the final angle, but you'll want it to be pretty close to the frame rail when done with a slight angle forward about halfway through so the cooler fits inside the fender liner.
Next, I went an grabbed some aluminum flatbar from Home depot and hammered out a simple bracket:
Additionally I bought:
2x 10AN to 8AN 90 degree hose ends (Fragola 229009)
6x 8AN hose ends (Russell 610035)
10 FT 8AN Nylon hose (Amazon)
5.2" Paddle Blade Pusher Fan (Spal 30103013) (VA31-A101-46S)
180 Degree Farenheit fan kit (Derale 16720)
8AN adapter with 1/8 NPT Sensor port (Russell 670353)
It is also assumed you've purchased or already have the 8AN transmission fittings and the Improved Racing 160 degree thermostat with 8AN fitment.
When mounted it will look something like this:
I did start to mock up the OEM bracket since I already had it but this metal is not good for bending and broke so a custom bracket will need to be made later:
I decided to mount the thermostat below the brake duct since there is a circular flat spot on the fender liner(MSport) that it should be able to mount to pretty easily. This is the position it will have:
Be sure to run the outlet to the top cooler port. If you go back to the transmission, the 'outlet' is on top, per realoem diagrams.
Now I mounted up the thermoswitch:
And here we are a few zipties later:
WIRING:
Per the chart above, I think that says the fan will draw 4-6 amps at 13v since I have the pusher fan. The pusher fan part number ends with "S" and not "A" so I am guessing that means Soffiante vs Aspirante. Makes me wonder if the motor is actually different or if the propeller angles are just optimized for one direction or another. In any case, we will need 22-23 gauge power wires.
Below are the specs of the fan, on the graph it is the red line, VA31-A101-46S:
It uses connector SUMITOMO Code 6010-2802, terminal code 1800-2093.
The female connector we need is 6110-4623 with terminal 1800-2094. You can find in various places including Amazon but I ended up ordering from https://www.corsa-technic.com since they provide the contacts with the housing in addition to listed documentation and a decent price. Truth be told, you should just depin/cut/splice but I'm weird.
FYI, regular female terminals actually fit inside of this connector so I'll be doing this temporarily until the actual connector shows up:
Possible Wires of interest:
B3Xa are the front PDC sensors but only have access to 5 amps if I am reading the diagrams correctly(probably not). E26 is the left fog light which is interesting as a manual switch. E126 is the left headlight. B42b (not shown) is the ride height sensor but I'm unsure if there is usable power
B43a TPM RDC Transmitter is also in this area, but the wire gauge is small.
Headlight:
Foglight:
Ride height Sensor:
TPM RDC Transmitter:
So it looks like I'll be looking for:
Yellow with Brown stripe fog light override
Black with Green Stripe headlight remote wire for thermoswitch
Dedicated 12v battery wire[/SPOILER]
Universal Small Bar and Plate Dual Pass Black Oil Cooler Core:9.5"x5.5"x1.58" | eBay
Find many great new & used options and get the best deals for Universal Small Bar and Plate Dual Pass Black Oil Cooler Core:9.5"x5.5"x1.58" at the best online prices at eBay! Free shipping for many products!
www.ebay.com
WIRING:
This estimate is based on nick-free soft annealed Cu wire having a tensile strength of 37000 pounds per square inch.
AWG gauge | Conductor Diameter Inches | Conductor Diameter mm | Conductor cross section in mm2 | Ohms per 1000 ft. | Ohms per km | Maximum amps for chassis wiring | Maximum amps for power transmission | Maximum frequency for 100% skin depth for solid conductor copper | Breaking force Soft Annealed Cu 37000 PSI |
0000 | 0.46 | 11.684 | 107 | 0.049 | 0.16072 | 380 | 302 | 125 Hz | 6120 lbs |
000 | 0.4096 | 10.40384 | 84.9 | 0.0618 | 0.202704 | 328 | 239 | 160 Hz | 4860 lbs |
00 | 0.3648 | 9.26592 | 67.4 | 0.0779 | 0.255512 | 283 | 190 | 200 Hz | 3860 lbs |
0 | 0.3249 | 8.25246 | 53.5 | 0.0983 | 0.322424 | 245 | 150 | 250 Hz | 3060 lbs |
1 | 0.2893 | 7.34822 | 42.4 | 0.1239 | 0.406392 | 211 | 119 | 325 Hz | 2430 lbs |
2 | 0.2576 | 6.54304 | 33.6 | 0.1563 | 0.512664 | 181 | 94 | 410 Hz | 1930 lbs |
3 | 0.2294 | 5.82676 | 26.7 | 0.197 | 0.64616 | 158 | 75 | 500 Hz | 1530 lbs |
4 | 0.2043 | 5.18922 | 21.1 | 0.2485 | 0.81508 | 135 | 60 | 650 Hz | 1210 lbs |
5 | 0.1819 | 4.62026 | 16.8 | 0.3133 | 1.027624 | 118 | 47 | 810 Hz | 960 lbs |
6 | 0.162 | 4.1148 | 13.3 | 0.3951 | 1.295928 | 101 | 37 | 1100 Hz | 760 lbs |
7 | 0.1443 | 3.66522 | 10.6 | 0.4982 | 1.634096 | 89 | 30 | 1300 Hz | 605 lbs |
8 | 0.1285 | 3.2639 | 8.37 | 0.6282 | 2.060496 | 73 | 24 | 1650 Hz | 480 lbs |
9 | 0.1144 | 2.90576 | 6.63 | 0.7921 | 2.598088 | 64 | 19 | 2050 Hz | 380 lbs |
10 | 0.1019 | 2.58826 | 5.26 | 0.9989 | 3.276392 | 55 | 15 | 2600 Hz | 314 lbs |
11 | 0.0907 | 2.30378 | 4.17 | 1.26 | 4.1328 | 47 | 12 | 3200 Hz | 249 lbs |
12 | 0.0808 | 2.05232 | 3.31 | 1.588 | 5.20864 | 41 | 9.3 | 4150 Hz | 197 lbs |
13 | 0.072 | 1.8288 | 2.63 | 2.003 | 6.56984 | 35 | 7.4 | 5300 Hz | 150 lbs |
14 | 0.0641 | 1.62814 | 2.08 | 2.525 | 8.282 | 32 | 5.9 | 6700 Hz | 119 lbs |
15 | 0.0571 | 1.45034 | 1.65 | 3.184 | 10.44352 | 28 | 4.7 | 8250 Hz | 94 lbs |
16 | 0.0508 | 1.29032 | 1.31 | 4.016 | 13.17248 | 22 | 3.7 | 11 k Hz | 75 lbs |
17 | 0.0453 | 1.15062 | 1.04 | 5.064 | 16.60992 | 19 | 2.9 | 13 k Hz | 59 lbs |
18 | 0.0403 | 1.02362 | 0.823 | 6.385 | 20.9428 | 16 | 2.3 | 17 kHz | 47 lbs |
19 | 0.0359 | 0.91186 | 0.653 | 8.051 | 26.40728 | 14 | 1.8 | 21 kHz | 37 lbs |
20 | 0.032 | 0.8128 | 0.519 | 10.15 | 33.292 | 11 | 1.5 | 27 kHz | 29 lbs |
21 | 0.0285 | 0.7239 | 0.412 | 12.8 | 41.984 | 9 | 1.2 | 33 kHz | 23 lbs |
22 | 0.0253 | 0.64516 | 0.327 | 16.14 | 52.9392 | 7 | 0.92 | 42 kHz | 18 lbs |
23 | 0.0226 | 0.57404 | 0.259 | 20.36 | 66.7808 | 4.7 | 0.729 | 53 kHz | 14.5 lbs |
24 | 0.0201 | 0.51054 | 0.205 | 25.67 | 84.1976 | 3.5 | 0.577 | 68 kHz | 11.5 lbs |
25 | 0.0179 | 0.45466 | 0.162 | 32.37 | 106.1736 | 2.7 | 0.457 | 85 kHz | 9 lbs |
26 | 0.0159 | 0.40386 | 0.128 | 40.81 | 133.8568 | 2.2 | 0.361 | 107 kHz | 7.2 lbs |
27 | 0.0142 | 0.36068 | 0.102 | 51.47 | 168.8216 | 1.7 | 0.288 | 130 kHz | 5.5 lbs |
28 | 0.0126 | 0.32004 | 0.080 | 64.9 | 212.872 | 1.4 | 0.226 | 170 kHz | 4.5 lbs |
29 | 0.0113 | 0.28702 | 0.0647 | 81.83 | 268.4024 | 1.2 | 0.182 | 210 kHz | 3.6 lbs |
30 | 0.01 | 0.254 | 0.0507 | 103.2 | 338.496 | 0.86 | 0.142 | 270 kHz | 2.75 lbs |
31 | 0.0089 | 0.22606 | 0.0401 | 130.1 | 426.728 | 0.7 | 0.113 | 340 kHz | 2.25 lbs |
32 | 0.008 | 0.2032 | 0.0324 | 164.1 | 538.248 | 0.53 | 0.091 | 430 kHz | 1.8 lbs |
Metric 2.0 | 0.00787 | 0.200 | 0.0314 | 169.39 | 555.61 | 0.51 | 0.088 | 440 kHz | |
33 | 0.0071 | 0.18034 | 0.0255 | 206.9 | 678.632 | 0.43 | 0.072 | 540 kHz | 1.3 lbs |
Metric 1.8 | 0.00709 | 0.180 | 0.0254 | 207.5 | 680.55 | 0.43 | 0.072 | 540 kHz | |
34 | 0.0063 | 0.16002 | 0.0201 | 260.9 | 855.752 | 0.33 | 0.056 | 690 kHz | 1.1 lbs |
Metric 1.6 | 0.0063 | 0.16002 | 0.0201 | 260.9 | 855.752 | 0.33 | 0.056 | 690 kHz | |
35 | 0.0056 | 0.14224 | 0.0159 | 329 | 1079.12 | 0.27 | 0.044 | 870 kHz | 0.92 lbs |
Metric 1.4 | .00551 | .140 | 0.0154 | 339 | 1114 | 0.26 | 0.043 | 900 kHz | |
36 | 0.005 | 0.127 | 0.0127 | 414.8 | 1360 | 0.21 | 0.035 | 1100 kHz | 0.72 lbs |
Metric 1.25 | .00492 | 0.125 | 0.0123 | 428.2 | 1404 | 0.20 | 0.034 | 1150 kHz | |
37 | 0.0045 | 0.1143 | 0.0103 | 523.1 | 1715 | 0.17 | 0.0289 | 1350 kHz | 0.57 lbs |
Metric 1.12 | .00441 | 0.112 | 0.00985 | 533.8 | 1750 | 0.163 | 0.0277 | 1400 kHz | |
38 | 0.004 | 0.1016 | 0.00811 | 659.6 | 2163 | 0.13 | 0.0228 | 1750 kHz | 0.45 lbs |
Metric 1 | .00394 | 0.1000 | 0.00785 | 670.2 | 2198 | 0.126 | 0.0225 | 1750 kHz | |
39 | 0.0035 | 0.0889 | 0.00621 | 831.8 | 2728 | 0.11 | 0.0175 | 2250 kHz | 0.36 lbs |
40 | 0.0031 | 0.07874 | 0.00487 | 1049 | 3440 | 0.09 | 0.0137 | 2900 kHz | 0.29 lbs |
Headlight:
This seems to be what people first gravitate to.
What I don't like about these wires is primarily the gauge thickness. All of these wires appear to be aprox 27 gauge
Connector | Pin | Description | Color | |
X13420 | 1 | Grey / Brown Stripe | ?? | |
2 | Ground | Brown | ||
3 | Signal, low beam | Yellow /Green Stripe | Left headlight | |
4 | Ground | Brown | ||
5 | Activation, bi-xenon shutters | Brown/ Yellow Stripe | Left headlight Right headlight | |
6 | Signal, high beam | White / Green Stripe | Left headlight | |
7 | Signal, parking light | Black / Green Stripe | Left headlight | |
8 | Signal, headlight vertical aim control | Yellow / Red Stripe | Left headlight | |
9 | Supply, stepper motors | Yellow / Brown Stripe | Left headlight Right headlight | |
10 | Signal, LIN bus | Blue / Red Stripe | Left headlight | |
11 | Signal, headlight vertical aim control | Blue / Brown Stripe | Left headlight | |
12 | Signal, front left direction indicator | Blue / Green Stripe | Left headlight |
Foglight:
X768 | 1 | Ground | Brown | |
X768 | 2 | Signal, fog light | Yellow / Brown Stripe | Left fog light |
Ride height Sensor:
Connector | Pin | Description | Color | Connector |
X18032 | 1 | Ground Ride height sensor, front | Grey / White Stripe | Ride height sensor, front |
2 | ||||
3 | ||||
X18032 | 4 | Signal, front level sensor | Grey / Green Stripe | Ride height sensor, front |
X18032 | 5 | Supply, level sensor | Grey / Brown Stripe | Ride height sensor, front |
Power wire seems thin so it may be able to act as a switched trigger wire.
For anyone unfamiliar with the bi-directional wheel electronics (not everyone has it):
They are mounted on the fender liners. I had to move their mountijng point because I put the cooler exhaust vent here:
Connector | Pin | Color | Signal Type | Description |
X18040 | 1 | Brown / Yellow Stripe | RDC_VL- | Ground |
X18040 | 2 | Black / Yellow Stripe | RDC_VL+ | Positive supply RDS transmitter, front left |
X18040 | 3 | Grey / Yellow Stripe | RDC_BUS | Signal, RDC receive antenna |
