Testo logging with DDE8 [help]
teddyax
Bicicyle
Hello guys,
Have anyone succeeded in logging BMW F series with DDE8 using Testo?
For example for logging an DDE7.3 the D73xxx.prg file (from Ediabas/ECU) is needed, which is already present.
But for DDE8 which would use D80xxx.prg file I suppose, is not present.
The car i want to log is a 2014 F10 530xd 258hp.
The tutorial I followed in order to be able to log F series is in the attachment. But for some reason, for DDE8 I haven't found a solution.
Thank you
  • testo.txt
