Speedtech Twin Scroll N54 bottom mount kit Released
Vitan
82
27
Pilsen, Czech Republic
Alpina b3s ST, Cls55 amg
EDIT: There will be an N55 version of this kit also!
Finally... Looking great, check out their web. Manifold is for 1000Usd.
https://www.speedtech.com/bmw-n54/
  • Manifold/downpipe/dumppipe arrangement advantages:
    • Efficient flowpath with consistent boost control
    • Keeps wastegate cold-side in cool air for reliability and easy spring changes
    • Places O2 sensors in ideal location to keep sensor body temps down to prolong life and allow easy access for service.
    • Fewest joints and welds for leak free, trouble free operation
    • Provides ample clearance from all hot-side components
    • Allows use of stock motor mount isolator
multiple turbocharger options
Decisions, decisions…. Choose from over 20 options from the best turbo manufacturers. With both T3 and T4 manifolds, you have many options:
  • BorgWarner
    • SX-E 252, 257, 362, 363, 364
  • Garrett
    • G25-660, GT 3071R, 3076R, 3582R, GTW 3476JB, 3684R, 3884R, GTX 3071R GEN II, 3567R GEN II, 3582R GEN II, 4088R
  • Precision
    • 5976E, 6176E, 6776E, 5558, 5858, 5862, 6062, 6262, 6266, 6466, 6766, 6870, 6875
Factory Fit and Finish
Clean engine bay, keeping the heat down low and out of the way, just like the factory intended. Lots of room for a generous sized air filter (important to minimize pressure delta across filter, as small filters can create pressure drops and increased turbo bearing wear, shortening the life of your turbo). Note - it is possible to keep the coolant overflow tank in original location, we just prefer moving it to give a cleaner look, and allow more airflow on turbo side of engine.
Included In the complete Kit
  • Turbo of your choice (T3 or T4 from BW, Precision, Garrett)
  • Cast Exhaust Manifold (divided for twin scroll), non-ceramic or ceramic coated options, single wastegate port (fully divided), O2 bungs (N54 version)
  • TiAL MVR or Turbosmart Hypergate wastegate
  • Tig welded 3” stainless steel downpipe
  • Tig welded 1.75” stainless steel wastegate pipe
  • RH engine mount support bracket, for use with stock isolator to maintain vehicle NVH
  • Billet aluminum coolant manifold
  • Silicone coolant hose from pump to block/manifold
  • Stainless braided oil feed hose
  • Billet aluminum oil drain manifold, fitting, hose
  • Billet aluminum oil and coolant block fittings and plugs
  • Billet aluminum intercooler adapter (stock style connection)
  • Silicone inlet hose (turbo to air filter)
  • Silicone boost pipe (turbo to intercooler)
  • Billet aluminum stock airbox adapter (N55 E chassis only)
  • Aluminum intake tube with billet PCV fitting (N55 F chassis only)
  • Stainless steel V-band clamp
  • Required fasteners and hose clamps
  • Full instructions with pictures
berns
175
266
'09 135i
Super stoked about this kit. Bottom mount, simple, affordable, keeps heat and weight low. Think I'll try it with a GTX3076R for my time attack 135i.
InnovativeAuto
76
21
Z4
Looks like a great option but $1000 seems pretty steep for a cast manifold IMO. Similar 2JZ & other models manifolds are a fraction of the cost. BMW tax I guess.
RSL
503
$2900"+". Seems the cheapest turbo is included at that price and up from there. Still on the fence about going single, but definitely want a bottom mount, smallish turbo and cast is good, so this might be an option. Any word on how long the intro pricing is expected to last?
Panzerfaust
635
438
Chicago
E92 335i
Definitely looks like a good setup and an excellent price. Even though I'm glad I stayed with twins despite having a high HP goal, I'm still glad to see an easily affordable single kit for people. Mostly because I think with more people having easy access to higher HP we'll start seeing the other things we need come quicker and cheaper, but I'm still happy for those of you who haven't upgraded yet :p
This should have been available 6+ years ago on this platform.
Glad to see it is now available and a nice list of turbos to choose from depending on your application/goals.
