SOLD SOLD
4doorbmwpower
90
42
South Carolina
cp-e.com
2007 BMW 335i (the CPE car)
okay so I am slightly confused here. I THINK I want this. But I currently have dual 450s upgraded lines/return, I have an external FPR and fuel pressure sensor linked up to my reflex+... now where would this fit in? Because obviously the stock driver side of the tank has a fuel pressure regulator/filter and venturi so would adding this result in me having to remove my current engine bay mounted FPR? My mind gets warped around whats upgraded and mated with stock at this point
From my understanding you would install this and set the supplied FPR equal to or higher than your engine bay mounted FPR, should take 2 seconds to set it. If you set it higher, the FPR does nothing and your engine FPR does all the regulation. This would free up the large restriction that is the driver's side top hat and give you a replaceable serviceable micro fuel filter vs. your stock fuel filter which is a restriction and probably has a ton of miles on it.
For you buddy I will make you a deal if you actually decide to buy it. Be glad to see it go to a good home!
Would it fit an E89?
I know it fits these models:
  • Bmw 1 Series M 2011
  • Bmw 128i 2008 to 2013
  • Bmw 135i 2008 to 2013
  • Bmw 135is 2013
  • Bmw 323i 2007 to 2011
  • Bmw 325i 2006
  • Bmw 325xi 2006
  • Bmw 328i 2007 to 2013
  • Bmw 328i Xdrive 2009 to 2013
  • Bmw 328xi 2007 to 2008
  • Bmw 330i 2006
  • Bmw 330xi 2006
  • Bmw 335i 2007 to 2013
  • Bmw 335i Xdrive 2009 to 2011
  • Bmw 335is 2011 to 2013
  • Bmw 335xi 2007 to 2008
  • Bmw X1 2012 to 2015
Unfortunately everything on the E89s seems to be unique!
