So im clear: a single walbro 535lph (295) pump w/o a check valve is fine for our cars on startup?
TiAgAu
139
56
08 335i
Another vote for the 295 which i've been running for close to 2yrs. No startup issues ever, just like oem. as said above pump primes when unlocking or opening door so it's an non issue
3,592
I have all that stuff ready to go for my car, along with Spool's overdrive unit. Unfortunately I think I'm going to mothball the Z4 and all the drivetrain upgrades as we are talking about putting our house up for sale and renting a while, until we figure out where we are going. More delays lol ... crap.
  • Sad
3,592
@Torgus Ok ... yeah gonna suck for a bit. But the other side of this will hopefully be a place with a large building for both wood shop work and garage with lift, etc.
Dumaurier7
560
230
A check valve is required not only to hold the pressure but keep the fuel line full of liquid, although the LPFP may prime quickly it cannot purge the Vapor out until you crank over the engine, this is where the delay comes from. I have a pair of 450s which worked perfectly then one or both check valves malfunctioned causing the very noticeable long crank situation, I kept the pumps but installed a Fuel Lab inline filter with check valve and now it’s back to OEM starting performance, my plan was to eventually chop out the intank filter and go inline to make servicing easy and more practical so this was a logical upgrade for me.
3,592
Well this brings up a good point. Also ... if this being the case, one wants that Fuelab cylinder very close to the LPFP. Halfway down the trans tunnel sort of defeats the purpose I would imagine.
Dumaurier7
560
230
I’ve got it located just about there like directly under the drivers seat and it works perfectly, remember that from the filter forward is fully pressured and actually holds a lot of fuel which is more than enough for the car to start up and idle giving the LP pumps enough time to fill up and purge the lines.
TheObjectivist
34
2008 BMW 535i
Cant help but laugh. Ordered the pump from PR hoping to slap it in over the weekend. Of course it arrives broken
marseille
94
56
E61 N54
I'd be curious to see how they fit a 295 into the stock 5 series bucket setup. My 535 xi bucket will not accept a 295 without a bunch of cutting.
3,592
Interesting ... doles the E60 run a different pump than the E8x/E9x N54? I bought a junkyard E89 Z4 bucket and the 295 pump clicked right in.
marseille
94
56
E61 N54
I believe it does. It runs a 540 LPH (open) Bosch pump that pulls 19A @ 80psi. It's taller and has a smaller diameter than the 295. The 295 will not fit in the bottom meshed screen housing that holds the pump and inserts into the bucket.
