Same cylinder injector keeps failing
mfractal
80
26
E90 Sedan LCI 335i FBO MHD E40
My cyl2 injector keeps failing
First time was during a wot pull about a year ago. I got an epc and half engine light
Pulled the codes and saw
112201 injector, cylinder 2 , activation : Line disconnection.
Car was running rough and removing the error would just bring it right back
I went ahead and changed all 6 injectors for new Bosch ones.
Fast forward to December. I installed the fx-150 pump and went for a test drive with it
During a WOT pull I got the same thing, half engine light, epc and the following error
110208 - injector, cylinder 2, activation : Low voltage side short circuit to earth.
stopped on the side of the road, erased the error and the car restated fine
Next WOT pull - same thing but now restarting and erasing the error would not help and car kept running rough.
I bough another brand new Bosch injector abs swapped it.
Everything was good until today where I went to test a new map revision and by the end of the wot pull - same thing with same error on cylinder 2
Since I was like 200km from home I didn’t risk testing again and just babied it home.
I’m sure once I step on it tomorrow it’ll fail permanently again
Question is - what can cause the same cylinder to always fail?
I feel the installation of the upgraded Hpfp increases the wear on the injectors and me running higher E content as well but I’ve never seen so many injection failures with anyone , let alone on the same cylinder.
Any tips ?
mfractal
80
26
I thought my mods are in my signature but they aren’t so here goes :
F10 LCI N55 535i with a similar to ps2 hybrid, fx-150 Hpfp, Walbro “274” Lpfp, n20 plugs, oem coils, Dp, ic. That’s about it.
This N55 has the 'solenoid' injectors right? On the N54 I've heard that running max pressure can cause the injectors to fail prematurely, despite not needing in excess of 3500 psi. What did your rail pressures look like prior to this injector failing and after the hpfp upgrade? In the early stages of this hpfp upgrade stuff, tuners may be sending everything they can.
mfractal
80
26
yes, these are the pencil type solenoid injectors (EU6 in my case) P/N 13647639994
I was actually datalogging while it happened, here's the log
Can't say the pressure is too high to be honest, and it doesn't explain the same injector failing over and over :confused:
Bnks334
530
344
This sounds like an electrical issue to blow through injectors like and with that type of failure. Check the ignition harness wires.
mfractal
80
26
Was suspecting that too. Any ideas on how to diagnose it ?
