Hello to all, I am new to the group and would like to share my build specs as well becoming a regular contributor. I'm not a mechanic and don't claim to know everything about this platform but will say I continue to learn daily. Doing a build of this level forces you to learn a lot unless you have someone else do all the research.
If you would like to follow the progress of my build I will do my best to update/answer questions on the forum but my Instagram will always be the most current. Check out @Nok1ds For more pictures and details.
Build Specs:
2015 non ZCP 30,000 miles
Stock bore/compression
Wiseco pistons
Pauter rods
Turbos -
Fuel-it stage 4 PI with 750cc injectors
Full port head job by HeadGames
ARP head studs
SSP Spec R clutch
FI Interchiller
Wagner top mount intercooler
CSF DCT transmission cooler
DSS rear axles
Maximum PSI crank hub fix
ESS CP's
BMS J-Pipe
VRSF downpipes
AA mid pipe
![20190301_155239.jpg 20190301_155239.jpg](https://www.spoolstreet.com/data/attachments/26/26799-c1aff6d2f19f4aac549d26cc7f383b8c.jpg)
![IMG_20190304_135949_276.jpg IMG_20190304_135949_276.jpg](https://www.spoolstreet.com/data/attachments/26/26800-e036dec7fbb678102e5788dfe049ae6f.jpg)
![vmacocss05_1063735634644-1-part-2000000000027821.jpg vmacocss05_1063735634644-1-part-2000000000027821.jpg](https://www.spoolstreet.com/data/attachments/26/26801-07643280f5e49d45d8bbbcd39c42c2e8.jpg)
![IMG_20190308_124909_576.jpg IMG_20190308_124909_576.jpg](https://www.spoolstreet.com/data/attachments/26/26803-f0def1336636168a3c0bc135ca24f4ef.jpg)
![IMG_20190308_203557_946.jpg IMG_20190308_203557_946.jpg](https://www.spoolstreet.com/data/attachments/26/26804-ad0a3a247d2f4cf93acf440e44b52fbf.jpg)
![IMG_20190308_124909_577.jpg IMG_20190308_124909_577.jpg](https://www.spoolstreet.com/data/attachments/26/26805-59ac26be013a159499fe7fce82dbfd54.jpg)
![IMG_20190311_163310_120.jpg IMG_20190311_163310_120.jpg](https://www.spoolstreet.com/data/attachments/26/26806-26b981eaefbb015d56dce25b965af636.jpg)
![20190425_162825.jpg 20190425_162825.jpg](https://www.spoolstreet.com/data/attachments/26/26807-373c867685ba9552b143f3b7204d15b8.jpg)
![IMG_20190423_095820_361.jpg IMG_20190423_095820_361.jpg](https://www.spoolstreet.com/data/attachments/26/26808-36f12aef48873ad06b485df840458cab.jpg)
![IMG_20190426_145159_318.jpg IMG_20190426_145159_318.jpg](https://www.spoolstreet.com/data/attachments/26/26809-7bc984c4a7c6113a3058a82a5a1278f4.jpg)
Build Specs:
Wiseco pistons
Pauter rods
Turbos -
ARP head studs
SSP Spec R clutch
FI Interchiller
DSS rear axles
ESS CP's
BMS J-Pipe
VRSF downpipes
AA mid pipe
