Hello fellow Spoolstreeters... looking to lean on a bit of your knowledge for help with a project. Many thanks again to those who have helped with the cooling/waterpump work in the past.
I'm in the middle of building an E92 335i racecar (build thread coming soon) and looking to keep the MSD81. Since it is a racecar, i'm looking to see what it takes to run the MSD81 as a standalone. To be clear, I know that the Motec, or Bosch Motorsport ECU are better solutions, that is not a path that I want to go down at this stage.
The car no longer has any of the factory wiring. So I need to figure out what the MSD81 needs in order to run the motor. Ultimate goal is to simplify and ditch the CAS, key, etc.
I'm open to any type of discussion with this. Additionally, if anyone knows the details or can point me to someone who has done it before it would be much appreciated!
Thank you,
Barry
Thank you,
Barry
