Removing secondary cats
pysical
471
108
2009 335xi E90
Is this a simple job for a basic exhaust shop? I am looking to get them removed and figured a exhaust shop should be able to do it? If not, is there a similar priced option for getting them removed? Was thinking about new exhaust that goes back to rear axle as I want to keep my mufflers.
_mhs
Should be simple job for an exhaust shop.
Borla makes a set of catless midpipes as well.
(Edit: p/n 60503)
mnick
26
7
Tampa
Simple, 60mins and $80.
Drone was terrible so I ended up getting hi flow cats and had the same shop put them on 4 months later.
Clarification: I am running Catless down
pipes and Dynatech PowerCat Catalytic Converter, High-Flow, 3-Way, Stainless Steel, 2.5 in. Inlet, 2.5 in. Outlet, 11.5 in. Length.
InnovativeAuto
76
21
Z4
Get ready for some stank! If it’s a DD I wouldn’t. And most exhaust shops are not going to remove all the cats (they can get a huge fine!). That might depend on where you live though.
pysical
471
108
2009 335xi E90
Did your car change in sound much when you got rid of the secondary cats?
And when you put the hi-flow cats on, did you lose sound and go back to normal? Or how was it?
I may do the hi-flow cats then.
mnick
26
7
Tampa
I have the 335is, not sure if our exhaust is the entirely equal.
Also I have/had Catless dps throughout the following.
I removed secondary cats from mid pipe, and the sound and drone was terrible (“fart burner”, as my Wife says). However, turbo spool was improved.
Then placed hi flow cats on mid pipe (instead of the 1792 resonator) and sound and drone was near perfect. No perceived change in spool.
And then... I upgraded turbos, and it’s loud again, currently thinking about options...
1,923
662
Then placed hi flow cats on mid pipe (instead of the 1782 resonator) and sound and drone was near perfect. No perceived change in spool.
New wife
Sorry couldnt help it
Seriously though have you tried seeing if could retrofit factory exhaust valve from non is exhaust
Reactions: SlvrR and mnick
