Pure_N54's Build thread
Andy
76
27
California
Car specs:
- 2010 E90 LCI 335i N54B30
- Black Sapphire Metalic
- M-Sport, iDrive, and automatic.
Here's a list of current and previous mods I've had on the car so far.
More pictures will be uploaded as I update the thread.
Feel free to follow my Instagram @Pure_N54.
Current mods:
Performance:
- JB4 w/ MHD custom backend flash
- VM/ACF Top mount ST kit w/ PTE 6466 Gen2 ball bearing turbo
- Evolution of Speed Port Injection w/ BMS PI controller
- Fuel-it Stage 3 LPFP
- Evolution Racewerks 6" intercooler/anodized black
- Evolution Racewerks charge pipe w/Tial BOV
- Vanguard V2 full catback
- AD-E low temp oil thermostat
- BMS Oil catch can
- RB External PCV w/ Mishimoto Oil catch can
Exterior:
- OEM M-Tech front bumper
- OEM M-Tech rear bumper
- OEM Performance diffuser
- OEM Performance CF spoiler
- OEM Performance gloss black grills
- OEM M3 E90 mirrors
- BBS LM 19x8.5 +17 19x10 +25 235/35/19 265/30/19 PSS with polished lip
- Apex 75mm stud conversion w/ Neochrome Project Kics R40 lugs.
- BavX LS3 angel eyes w/ full blackout
- Vollkkomen Design lip
- LTMW custom CF splitter
- 35% 3M ceramic tint all around
- M3 side skirts
- StealthExclusive CF side splitter
- Evolution Racewerks engine cover
Suspension/Brakes:
- KW V2's
- OEM M3 Front/lower control arms
- OEM M3 Strut brace
- OEM M3 E93 sway bar
- HPA Adjustable sway bar end links
- M-Factory LSD 3.46 gearing small pumpkin
- Polyurethane diff bushings
- Diff Lockdown brace
- Stillen/AP Racing J-Hook rotors
- Akebono Euro brake pads
- Stoptech SS brake lines
Interior:
- OEM Performance steering wheel
- OEM Performance Shift knob w/ alcantara boot
- OEM Performance E-Brake w/ alcantara boot
- OEM M3 cluster
- Avery Dennison Brushed aluminum interior trim wrap
Andy
76
27
California
Past mods:
- Stock turbos
- VRSF Catless downpipes
- PE Exhaust
- RB Inlets
- Pure stage 2 turbos
- ER CP w/ Forge DV's
Maintenance done:
Oil changes done with AMS oil 5w30: 50,000/55,000/60,000/65,000/
Oil change done with Motul 8100 X-Cess 5w40: 69,600, 75,000, 78,500, 82,500, 85,550
OEM Bosch Spark Plugs: 41,719/62,000/73,000
NGK Spark plugs 95770: 80,800/ 85,550
Ignition coils: 62,000 Bosch/ 73,000 Delphi/ 85,550
Walnut blast: 60,000/ 80,000
OEM turbos replaced at 65,000
Valve cover gasket replaced at 41,719,65,000,84,000
Valve cover replaced: 41,719
AC Evap leak fixed: 65,000
Six new index 12 injectors replaced: 65,000
Radiator/fan/fuses replaced at: 60,014
Serpertine belt/belt tensioner replaced: 65,000, 84,000
Brake pads (Akebono) replaced: 68,000
Coolant flushed/replaced w/ OEM coolant: 62,269/68,500/78,500/84,000
Brake fluid flush/change w/ OEM brake fluid: 20,028/41,719/60,014/71,000
Power steering fluid flushed: 84,000
FRM3 Module: 59,600
All vacuum liines replaced: 78,500
Replaced front/rear turbo oil drain lines: 68,500
RB PCV: 60,000
HPFP replaced: 10,494, 85,000
Transmission fluid flushed w/ ZF fluids: 85,000
Oil pan gasket done: 85,000
Oil level sensor replaced: 85,500
Mechatronics sealing sleeve: 85,000
Water pump/thermostat done: 84,000
To do list:
- Megan rear toe arms
- Megan rear camber arms
- AP Racing BBK
- Built auto or manual swap
- Built motor
Duplicities
24
E90 335i FBO w/ Inlets (soon)
Can you post pictures of your interior? This is basically what I have in mind for my car so it's cool to see someone who actually is running it right now.
dt20011
11' 335is
Following you on IG, very choice build, really like it.
How long did it take to get your ST kit from ACF? Was is faster since your local?
Andy
76
27
California
Hey, man. What's your IG?
Thank you, appreciate it!
I only had to wait about a week or two max for my kit. Maybe if it was faster cause I had it installed at ACF as well.
dt20011
11' 335is
Nice steering wheel, I'm gonna have to follow your lead on this lol. I'm new to the n54 scene , I came from a f series n55. There's so much info posted I've been lurking around trying to wrap my head around everything. IG = project335is
Andy
76
27
California
Oh! It's you! What made you move on from the M235?
The N54 power is so different compared to the N55, I hope you enjoy it.
You're in SoCal, right?
dt20011
11' 335is
Ready for a change and I think I had just about hit the limit of my particular N55 set up. I definitely love the new car , stock for stock I feel the 335is is superior to an M235i.
The M235i just feels super soft and floaty while the 335is feels tighter, more engaging and IMO looks better out of the box.
Yup, I'm in Temecula.
