Hi Everyone,
So the PS2 turbo is known to have some issues on high boost targets, and I believe it also affects other hybrid or bigger turbos for N55 on the market.
Fact: High Elevation = Lower air density = less air getting into the cylinders
I was wondering what a realistic boost expectation was for the PS2. Im at 5000ft and the PS2 turbo is maxed out at 22 psi and tappers down to 18 ~ 19 psi.
If there are other people running this turbo at a high elevation and only making the same boost as me, then I will stop hunting for boost leaks. So far I've done 3 or 4 boost leak tests by pressurizing the intake tubing from the turbo intake feed. Already changed twice the intercooler couplers with t-clamps, boost solenoid is brand new, etc. WGDC is still maxed out to 100% above 5000 RPM.
I would like to hear from other people, maybe people from Colorado who have similar elevation levels as I do here in Guadalajara, Mexico.
Thanks in advance,
Ganque
Thanks in advance,
Ganque
