SOLD PSP intercooler
SJ_1989
368
299
Illinoisssss
2008 E90 335i
I have a brand new 900 I'd let go. Never used other than installed for test fitting. I can send pics tonight if you want.
PupkinRacing
79
21
Madison, Wisconsin
Bmw 135i
I have the AD Eng 650 IC, which is very similar to the PSP 700. http://www.ad-eng.net/store/p39/ADE_BMW_135/335_650HP_Intercooler_(6MT).html
It would only fit a manual car though. Also requires the AD Eng charge pipe because it is 3in all the way from IC to throttle. I can sell you the whole setup, IC/CP/TiAL bov.... Let me know if you're interested.
I mite be interested. I have a manual trans car and a 3inch chargepipe/tial already so I would be good there
e30gentry
45
23
2008 135i 2008 CLS63 AMG 335D
PSP intercooler are amazing, we track and daily our 135i auto in Texas and always keeps IAT in check.
I hope you find one, you won't be disappointed
Reactions: PupkinRacing
PupkinRacing
79
21
Madison, Wisconsin
Bmw 135i
Thanks for that info, makes me feel better about it. Iam supposed to be meeting up with SJ this Saturday to buy his. Very excited to finally get one
Reactions: SJ_1989
e30gentry
45
23
I have their 750 and it's overkill for my stock turbos but I really wanted something I wouldn't outgrow.
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
i dont see the big fuss about PSP intercooler, there are no positive data to back up any of the intercoolers manufactures claims. vrsf race has been proven time and time again that its the best in the market with plenty of data to show for it . unless im missing out on something i dont think anyone should buy psps intercooler. cast ends are far superior compared to sheetmetal ends. also vrsf's fine pack is by far best of the best
e30gentry
45
23
I can provide daily driven in traffic logs, high heat high temp logs on 2-3-4 gear pulls.
Not going to argue anything here VRSF has come a long way in the past years, but like I stated my car is a dual purpose car and I use the 750, which I why I noted my experience and the PSP 750 can't be compared to the noted VRSF race core.
I don't need something like that specific VRSF RACE due to traffic driving in Corpus Austin and Houston. The PSP does better in those situations with minimal IAT temp gains.
Also let me note I am in no way going to or trying to argue anything mentioned by Vader Solutions as I am sure you all have way more experience testing anything N54 related compared to what I have done.
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
well i have seen plenty of data for psp in regards to stock boost to around 14psi via stock turbos. these kind of data does not mean anything. its when you start to generate more heat, more boost, bigger turbos is when the vrsf intercooler shines. so in that regard i havent seen any data. all my race cores from vrsf drop iat during pulls at 30psi on a 65mm turbo.
Cruizinmax
128
73
09 335i
Why is it that no one seems to be providing actual efficiency data on these intercoolers? What I would like to see is inlet and outlet temperatures and pressure drop across the core. For all we know 20psi from the stock turbos maybe putting out hotter air than your 30psi on the 65mm turbo. The fact that that your temps drop during the pull may not be as relevant. Additionally pressure drop would be a better indicator of how restrictive the internal structure of the core is.
2,198
Because there is no money in it...the cost to accurately test what you are asking for across stock twins, upgraded, and say a 6466, would be very expensive. Now data I would love to see but no shop or vendor is going to spend the time and effort given all the intercoolers, turbos, fuel available, etc. And the top two are going to come out very close I would imagine and also very close to a custom bespoke IC using good cores etc.
VRSF or BMS big boy IC seem to be the best bet. I believe I have read of stock frame turbos and about everyone else not complaining about or noticing much lag with the largest IC over stock.
Twins will output more heat generally given how most people size their single turbos.
Go big or go home.
