Proper NBT EVO menus integration into EXX
superwofy
143
221
So while I'm sure almost everyone knows that you can replace the main menu PNG, there are still many menus where the 3D model of an F series car persists and is quite ugly.
To fix this, I've disabled the widgets selectively in the areas where I feel they shouldn't appear. There are still two important areas where they have to remain and they are: PDC and tyre pressure. However, from those angles the F32 looks similar enough to my E92 so I don't particularly care.
Copy the source files to the root of a USB drive, SSH/Telnet in and run these commands:
Bash:
mount -uw /fs/sda0 && \
cp /fs/usb0/cp_fahrerprofile_aktivieren.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/content_preview/cp_fahrerprofil_aktivieren/ && \
cp /fs/usb0/id6hero_f32.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/Main/Heroes/hero_myvehicle_F32/
cp /fs/usb0/roll.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/MyVehicle/DrivingExcitement_xDriveView/xdrive_roll/ && \
cp /fs/usb0/slope.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/MyVehicle/DrivingExcitement_xDriveView/xdrive_slope/ && \
cp /fs/usb0/xdrivestatus.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/MyVehicle/DrivingExcitement_xDriveView/xdrivestatus/ && \
cp /fs/usb0/front_f3x.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/CP_climate_on_off_red/CP_climate_on_off_red_F30/ && \
cp /fs/usb0/front_f3x.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/CP_climate_selected/CP_climate_selected_F30/ && \
cp /fs/usb0/front_f3x.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/PCC_climate_on_off/PCC_climate_on_off_F30/ && \
cp /fs/usb0/front_f3x.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/PCC_ecopro_climate_on/PCC_ecopro_climate_on_F30/ && \
cp /fs/usb0/front_f3x.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/PCC_climate_fix/PCC_climate_fix_F30/fond_f3x.png && \
cp /fs/usb0/buo_audio_f13_direct.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/Preview_BuO/Preview_BuO_F13/ && \
cp /fs/usb0/buo_audio_f13_open.png /opt/hmi/ID5/data/ro/common/assetDB/Domains/Vehicle/Preview_BuO/Preview_BuO_F13/ && \
cp /fs/usb0/interior_f30_display.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/Vehicle/cp_int_cd/cp_int_controldisplay_F30/ && \
cp /fs/usb0/interior_f30_display_popup.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/Vehicle/CP_int_cd_popup/cp_int_cd_popup_F30/ && \
cp /fs/usb0/contentpreviewxdrive_f25.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/Vehicle/XDrive/SSc_xdrive_F25/ && \
cp /fs/usb0/camera_and_vehicle.lua /opt/hmi/ID5/data/ro/common/script/ && \
cp /fs/usb0/cid_hm_settings_bg.png /opt/hmi/ID5/data/ro/bmw/id6l/assetDB/Domains/MyVehicle/Einstelloptionen_Hauptmenu_Inhalte/cid_einstellungen/ && \
cp /fs/usb0/69e87ef3df72423ctex_carpaint_ao_bitmap.png /opt/hmi/ID5/data/ro/bmw/widgetasset/vehicles/F32/vehicle/bitmaps/ && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_tirepressure_reset/3dcar_tirepressure_reset.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_tirepressure_reset/3dcar_tirepressure_reset.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_doorlocking/3dcar_doorlocking.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_doorlocking/3dcar_doorlocking.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_mirror/3dcar_mirror.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_mirror/3dcar_mirror.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_exteriorlight/3dcar_exteriorlight.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_exteriorlight/3dcar_exteriorlight.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_mdrive/3dcar_mdrive.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_mdrive/3dcar_mdrive.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_oil_measurement/3dcar_oil_measurement.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_oil_measurement/3dcar_oil_measurement.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_stability_control/3dcar_stability_control.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_stability_control/3dcar_stability_control.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_traction_control/3dcar_traction_control.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_traction_control/3dcar_traction_control.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_cbs/3dcar_cbs.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_cbs/3dcar_cbs.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_ccm_detail/3dcar_ccm_detail.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_ccm_detail/3dcar_ccm_detail.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_pia_guest/3dcar_pia_guest.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_pia_guest/3dcar_pia_guest.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_welcome_start/preview_car_welcome_start.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_welcome_start/preview_car_welcome_start.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_exptec_preview/preview_car_exptec_preview.pbw /opt/hmi/ID5/data/ro/common/assetDB/3d_car/preview_car_exptec_preview/preview_car_exptec_preview.pbw.disabled && \
mv /opt/hmi/ID5/data/ro/common/widgetasset/vehicles/common/vehicle_EA_EF/widget.pbw /opt/hmi/ID5/data/ro/common/widgetasset/vehicles/common/vehicle_EA_EF/widget.pbw.disabled && \
sleep 5 && \
mount -ur /fs/sda0 && sleep 5 && OnOffDSICommander appreset
As always, comments/suggestions welcome.
  • source-files.zip
Reactions: zomboi09 and wheela
zomboi09
10
great, I also want to change them for some other car models so let me ask, where can I find to download these PNGs
superwofy
143
221
I added a sunroof.
I'm sure much more work can be done on this bitmap to make the F32 look more like the E92.
