Ad: Product Release - VTT Ultimate E9/8X Rear Brake Conversion kit
Oct 24, 2016
1,152
1,203
Scottsdale, AZ
VTT ultimate E8/9X ultimate rear brake conversion kit
VTT is happy to announce its new rear brake conversion kits for the E8X/E9X platforms. We take what already exists on the market, and make it much more complete, and much more performance-oriented while keeping the clearance for those 15” wheels. This kit replaces your rear brake rotors and calipers to fit 15" wheels. It includes lightweight Wilwood calipers to go from the single-piston factory caliper to race-inspired 4 Piston calipers. While dropping up to a whopping 20 LBS of unsprung weight off the back of your vehicle!
The kit consists of:
· 2 Rotors (Plain or Cross drilled) Plain are Centric 125 Series, and Cross Drilled are Genuine Stop-Tech rotors
· 2 Wilwood 4 Piston Calipers
· 1 set of high-performance Wilwood street pads. (option to remove the pads, and get your own compound pads)
· All hardware required for the swap, including brackets. bolts, and adapter fittings
· Stainless Steel upgraded rear brakes lines as an option
These kits will bolt directly on to the chassis specified, BUT many different 15” wheels in many different offsets exist, we cannot guarantee this will clear your wheel/tire combo without some clearance. We can 100% say they clear Weld RTS 15x10 as this is what we tested on.
Conversion weight numbers:
Calipers with pads
Factory Rear Caliper 9.8LBS
Stock Style Rear 15” conversion caliper 8.2LBS
Wilwood Rear calipers 4.5LBS
Savings of 1.6 Lbs. per side or 3.2 lbs. total from factory to stock conversion style
Saving of 3.7LBS per side or 7.4LBS Wilwood over stock style
Savings of 5.3 lbs. per side or 10.6 total from Factory Rear brakes to Wilwood 15” conversion
Brake Rotors
Factory Size Rotor 18.2LBS
Cross Drilled 15” conversion rotor 13.5LBS
Plain 15” conversion rotor 14.4LBS
Savings of 4.7Lbs per side or 9.4 Lbs. total going from a factory rotor to 15” conversion cross-drilled
Savings of .9 LBS going cross-drilled 15” conversion over plain
Total savings
Factory rear brakes – 56LBS
VTT 15" Plain Rotor Wilwood caliper 37.8 Lbs. - Savings 18.2 Lbs.
VTT 15” Cross-Drilled Rotor Wilwood Caliper – 36 Lbs. – Savings 20 Lbs.
Kits start at $599, and we have one full kit in stock now for immediate shipping with enough parts for 5 more kits as soon as the brackets arrive in about a week.
On the site here: http://performance.vargasturbo.com/ecommerce/index.php?route=product/product&path=65&product_id=132
IMG_20190612_1351109 - Copy.jpgIMG_20190612_1351344 - Copy.jpgIMG_20190701_1343115.jpgIMG_20190701_1558562.jpgIMG_20190701_1559047.jpgIMG_20190701_1559513.jpgIMG_20190701_1600314.jpgIMG_20190701_1600390.jpgLines.jpg
SJ_1989
368
299
Illinoisssss
2008 E90 335i
Funny, I was piecing together almost an identical kit but you designed the bracket for me....winning.
Nice to see someone stupid proof this in a ready to go kit. Maybe some measurements would be useful so people could compare it to their wheels?
Reactions: Panzerfaust
Milan
413
241
jebi se
your mom
Good deal honestly, if this was for a GTR it would be $2-3k lol
I like using the Wilwood calipers too, good choice.
LoBoost
251
172
2008 135i, 2014 GTR
@Chris@VargasTurboTech any plans for a July 4th sale? I'm going to order for sure, but would't be too happy if I paid full price today and there was a discount code provided for tomorrow!
Also, any idea what offset / backspacing works well on the 135i for 15 inch Weld's?
Payam@BMS
412
265
34
Ohh we need this for our white 135i!
Yes, this method is easier and cleaner esp for your car. No grinding or anything compared to the 15" conversion I have.
Then we can put 15" with fat tires so I won't spin off the track this time :rolleyes:
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Awesome! Does this have any issues with the parking brake shoe on the 135i? I don't have firsthand experience with this, but I've read about having to modify or deal with the shoe hanging out when researching 15" brake conversions.
Oct 24, 2016
1,152
1,203
Scottsdale, AZ
Our experience was these issues were due to very low-quality cost rotors being sold with some kits. These are genuine stop-tech rotors, and should have no issues fittings E8X, and E9X
E89 runs an electromechanical rear brake. It is a completely different animal.
Terry@BMS
Jan 23, 2017
463
375
Same thought. We need to get that car setup so I can have some fun with it. Hate to have something I spent $100k on over the years sitting in the corner of the office lol.
