https://datazap.me/u/chi-townspeed/log-1507592497?log=0&data=3-24
I was leaning towards one of the oil lines whether it be the feed or return due to me not experiencing any noticeable issues from this.Could deff be the cartridge itself I've seen those leak.. but the amount points to possibly the feed line and or it's oring
My wallet will certainly pass on that lol. If this will lead to a turbo replacement, I will most likely go on twin upgrade.Welp, time to go single turbo!
Do the labor yourself and you'll be on budget.Total budget on turbo and install is around 3k for me.
Really wish I could!! It's a pretty big job for me to do alone. Garage is currently filled with family junk and it's too cold to do it on jack stands in my garage. Also have the xi version which makes everything a greater pita. I'm just petrified of the exhaust manifold bolts.Do the labor yourself and you'll be on budget.![]()
I tried to do some more digging but came across nothing. Car has been running perfectly fine, no smoke whatsoever, no excessive oil consumption, however the car is still at stock boost though. Still haven't turned up boost due to having no where to install downpipes.What was the verdict?
Never have to top it off from oil change to oil change. Oil interval is approx every 4000 miles. Digital oil level maybe goes down 1/4 - 1/3 down. No oil leaks. No stains on driveway.define "no excessive oil consumption"
