yes you can. with big battery on the car. you'd better use lion battery as it can provide 13.X Voltage before running out. when is possible , charge it.
Reason is just me being me mateI wouldn't do it. Could you? Maybe. The alternator provides a nice steady voltage which keeps things happy.
I have had to sit in the lanes for a long time waiting to go for a run. Now you have very little amperage draw which is good, I would clamp a meter on and see exactly how much it is drawing.
When the voltage gets low the electronics do weird things. Not what you want when WOT in the 1/4.
You save a couple of pounds for the alt and obviously a small bit of power is 'gained' by not having the losses of the engine when connected to the alt via the pulley but it is sooo small I don't see how it would matter.
I would keep the alt and go with a lightweight battery.
What is your reason for wanting to do this? It sounds like more of a hassle, even if it did work fine.
You guys know that the alternator shuts down at WOT, don't you?
Nope. Why does it?
It will still have a parasitic physical load on the engine from the belt/pulley right? There is no clutch on the pulley or something to that effect?
Simple answer, because you're requesting maximum power.
Same reason the A/C shuts down on WOT. Cut down on things that eat up power.
Pull the belt and spin the alternator. Yes there's some drag. But it's not enough to loose sleep over. There's far better ways to get more power than making more work for yourself at the track ... dragging more shit with, charger, generator, fans, fuel, ice, jump pack, spare battery, ... ... ... and then you get beat by a car that drove there.
And IIRC the options for the alternator are on the coding side.
@Sausage what are the implications of removing/disconnecting the IBS? I assume you need to code it out?
Somehow I have misfires at WOT when I keep my IBS connected. Something in the IBS system is causing the car not to have the amount of power required. Didnt figure out yet why.
When disconnected, the car/alternator is always charging (14v+) causing higher alternator wear and increased resistance/consumption. I think it triggers a code somewhere but nothing noticable on dash/idrive.
Please pardon the ignorant question, but when you guys are talking about misfires, are you talking about limp mode/half engine light misfires where you have to restart the car? Or are you simply checking codes after a pull and seeing misfire codes listed?Somehow I have misfires at WOT when I keep my IBS connected. Something in the IBS system is causing the car not to have the amount of power required. Didnt figure out yet why.
Its been a while since ive looked at the issue but I noticed alot of high 11's while driving/cruising. Also seeying high 11 when turning on ignition. Dropping to 10.x shortly when starting.I assume with a healthy battery the car sits at around 13.2v?
