Okada Coil Testing (Snake Oil or Real Deal?)
PRECISION RACEWORKS
Nov 11, 2016
145
282
HOUSTON TX
www.precisionraceworks.com
We have wondered about the “Okada Plasma Coils” for some time now. It was always speculated they were snake oil. The claims below we copied and pasted directly from Okada advertising for these coils are pretty bold.
“The IP Coils are the ignition coil with a high power amplifier built in to it. The IP Coils produce 4 times more spark energy than stock coils and also generate an ultra-fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reachmany more molecules and therefore accelerate the ignition and combustion process.”
Right away we laughed at the “multi spark discharge of 10 sparks to highest RPM” this claim is 100% impossible. The DME controls multi spark you already have it and it doesn’t work in higher RPM. The only way to add multi spark to any coil is to modify the control system sending the signal and they have added nothing in the system capable of doing this. So far they have started out with knowingly misrepresenting their product. But the 4 times spark energy would be a great thing to test as it is possible to have more output from a coil (not sure how they would cram the extra windings into such a small package but it deserves testing before calling it false as well).
So what voodoo is going on inside these coils that make them capable of 4 times more spark energy! They aren’t changing the dwell time because there is no flash of the DME so for starts they must be ¼ the resistance. Factory is 0.50ohm so these should come in by ohms law around 0.125ohm across primary coil. But before we get to actual testing, as we always do we will evaluate a product first to see what physical difference there is.
Right away we noticed that both coils have all of the Bosch factory branding on the sides, the factory Bosch laser marking as well. The only physical appearance is an area on the Okada coil is where what appears to be cutting an piece of plastic that is an empty void, putting a piece of bent anodized aluminum with a sticker on it there and filling the now even larger void with epoxy. This made us curious did they use this void for something?
When we took the clip off both coils we did find that Okada did make a part on this coil, they made their own clip (the factory one does not clear the added aluminum and epoxy). You can even see their logo marked into the clip itself.
We always weigh things as well to see how they compare it can tell you a great deal. The Okada coil pretty much weighed the same as the factory Bosch coil only 0.1oz more this is about what we would expect the aluminum and the extra glue to weigh. But we still can’t help but wonder if possibly they stuck something in that void to achieve their claims.
As you see they are both identical at 0.50ohm so what magic are they using in these things that break simple electrical laws that no one has ever dis-proven? (our wires alone were .3 ohm so this must be subtracted from the coil measurement to not have the resistance of the wires factored in)
They weight the same basically, they measure the same across primary circuit, they have all of the same factory Bosch markings from molds and batch numbers. Everything is identical except the little piece of red anodized aluminum and the extra epoxy. The only “Engineered” part is the plastic clip on the top which won’t create 4x the spark energy. Maybe the guys over at Okada figured out a little something magical that weighs almost nothing they could solder to the terminals on the back side. Only thing you can do is test them and find out does the voodoo work because electronically so far there is no difference. (The secondary winding on these can’t be measured without destroying the coil so we couldn’t test this on the Okada)
TIME FOR BENCH TESTING
So we connected the factory Bosch coil first (old used one pulled from junk drawer) ran the coil recorded some numbers as you can see below . Then we unplugged the old Bosch coil and fired up the fancy new Okada “Plasma coil” to see what the $800 (on sale) set of 6 coils really got you. As you can see comparing the Okada on the Right to the Bosch on the left we had a great surprise (not really) they tested almost 100% identical for current input and saturation point. So in short it is not possible to create more power out of thin air, if two coils pull the same current they both have the same power.
But what if they changed the secondary windings in these coils this is possible…. As mentioned above we couldn’t test it without cutting in half and since these were loaners we weren’t able to do that. We could measure actual output but it’s more fun to play sometimes and we weren’t wondering anymore if they really could be anything but Bosch coils with some glue, a piece of anodized aluminum, and a cheap sticker. So let’s toss one of each coil up on the free air test box and watch sparks jump. Here we suddenly took a step back and said whoa the Okada do outperform the Bosch what is going on here! We really did think it was magic even swapped sides of the test box to see if ground path was slightly different giving the Okada a leg up. To our surprise it still out performed the Bosch coil. So we shut things down scratched our heads and decided the gods bless their coils and they truly are superior. Then while talking and looking at the coils we noticed dates laser engraved on both coils by Bosch. Our test Bosch coil was from 2007 and was most likely in the junk drawer for a reason. So one of our guys went to their car and grabbed some spares that were kept in their trunk to our surprise these were 2013. Still not on par with the Okada that had less than 100 miles on them but hey beggars can’t be choosers. Sorry we didn’t snap any pics of the free air test but ran this coil back through the paces and literally EVERY number was an exact match for the Okada and on free air test both performed 100% identical
Sorry for not being as fun to watch as Myth Busters really wish they did a test on these magic Plasma Coils that are blessed by the gods. But regardless this myth is busted, it is all fancy words and marketing on something the general public either doesn’t know how to test or doesn’t have the equipment to test. So many people have bought $799+ coils as an “upgrade” and received the same coils they already had just new ones that weren’t tired like the first one we put on our test bench.
1,285
779
Capitalism at it's best/worst?
Great review. It's always good to see empirical data and not just anecdotal "evidence."
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Isn't there another component in their kit? The plasma ground?
Appreciate the testing!
Erichale77
827
447
Clearwater, FL
07 E92 coupe
I have both the coils and plasma ground. Seem to work fine for me although i haven't performed any scientific testing. I plan on running these until they take a shit and then buy your coils. P.s I wish you didn't decide on "blue" coils. Hehe
Reactions: PRECISION RACEWORKS
Danksies
180
55
NoVA
Damn and here I thought no one could be worse on branding tax than BMW lol. Really appreciate whoever bought these and let PR test on them and PR for actually testing. Need more posts like this that point out them fakes
Reactions: matreyia
jsyeah
Not to side-track the article, great myth busting by the way.
To accurately measure resistance at 0.5 Ohm, I think you should do a 4-wire measurement to eliminate cable resistance (it's better than trying to subtract out contact resistance from the probes).
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Some people attempt to buy the best upgrades on the market for their build regardless of price because money isn't an issue. If something better is developed or presents itself we just replace it with that.
1,634
There's certainly a good cause of action here for deceptive advertising and/or unfair trade practices against "Okada" or whoever is promoting these coils. I also see a possible class action law suit.
Reactions: Jake@MHD
dyezak
1,767
1,518
Plano TX
335is
If money is no concern, they wouldn't be driving a 135/335/etc. This isn't the Lambo crowd buying a turbocharger for $20k (sorry Tony) and fuel pumps for $4k.
TWilly
85
18
Tyler
This is an awesome review. You guys should keep up with these. I'd personally like to see comparison to the BimmerLife Tuning coil set up
1,634
I quickly googled found these sets for N54 about $1000...any guesstimate how many sets have been sold? I also see Okada Plasma direct could for many different platforms. I wonder if those other ones are also repackaged OEM....hmmm...
How big of a company is Okada?
(I have a couple of lawyer friends who may be interested in looking into this further.)
Danksies
180
55
NoVA
I agree that I'm one of those that likes to buy the best part or whatever regardless of the price (cause I work hard for my $), but you should still be checking if the parts you're buying are even doing anything lol. I can't imagine if someone is running a big power setup and bought these, that they wouldn't test to see if they're getting their $1000 worth. You'd figure that there would be enough negative reviews that would deter people from buying rebranded some bosch's lol
You can still be in a situation where you're comfortable and money is not a concern for hobbies. And this still is the BMW crowd, not the Honda crowd prices lol
I bought these coils based on a documented test that showed significant performance improvements - and when I installed them while tuning with Ken at Wedge Performance, I noticed an immediate improvement in power delivery and zero misfires. This is after replacing my stock new oe coils.
That being said, after these go bad...and they will - I will give Precision Raceworks coil set a try to see if there are truly any differences. I don't know why Robert did not find any difference between the oe and okada coil I supplied, but I won't discount his process...at the same time, I did and still do notice a significant improvement from stock coils.
I am a person who knows every change at any time when it comes to my car.
  • Sad
Reactions: topher335
1,634
I would love to see the before and after logs.
