no start..
denobd
14
535i
good morning guys.. back again. someone please help me figure this out.. so couple weeks ago had a ekpm3 that failed. car would not start. had to replace it anyway so in preperation for the new upgraded twins i got i decided to just upgrade the whole fuel system.
brand new EOS fuel pump controller
brand new spool performance LPFP
brand new FCP euro HPFP
brand new index 12 injectors.
car started and ran for about 5 min then died. now cranks but wont start at all. and is throwing these codes..
29f2-dme:fuel-high pressure system
2a2d-dme:fuel-low pressure system.
any help would be great..
dpaul
2009 E90 335xi, 2011 E93 M3
It is often a mistake to change too many variables at one time. You can do what NoGuru suggested because it's not very difficult.
But here are two simpler approaches 1) use INPA to directly monitor LPFP or 2) just listen for the typical pump priming sound from the LPFP when you unlock the car or open a door. That Spool LPFP should make a noise easily discernable standing outside the vehicle without removing the rear seat or anything else I'll predict you don't hear the pump i.e. the LFPF is not being activated. This could reflect a faulty component but is more likely an electrical problem that you've created for yourself by forgetting or misconnecting a wire/plug to the new LPFP or EKP substitute. I'd concentrate my troubleshooting effort on those components.
I actually had a refurbished pump go bad after about 1 mile. After swapping it out multiple times with other pumps, undeniably the pump had gone bad in some way. I suspect your HPFP is bad, send it back.
Bmwfixerguy1
875
292
07 335i MT
You should still be able to limp the car on low pressure if a hpfp is bad.
1. Make sure pump is running it will only run while cranking or running engine.
2. If pump is running make sure all lines in tank are good feeding up to the pump and that fuel is actually in the bucket
zomski101
48
9
What was the solution to this? I have the same codes and symptoms. My car died while on the highway. Everytime I start it up lpfp pressure is at around 32 psi and rail pressure is at 700 psi. After minutes of idling the lpfp pressure slowly goes down to 20 psi and then rail pressure begins to drop until it reaches 70 psi then the car dies. I have stage 3 dual walbros, bpm4 and helix 3x.
1,634
Have you tried changing out the LPFP sensor? I understand they go bad after a while. Temperature can effect a bad sensor...as the engine warms and heats the sensor, it could read differently.
