Nightmare diagnosing n54
Msport335
116
26
Need everyone's tuning expertise ! Brand new index12s , plugs , coils and 4 new o2's and still getting rough cold starts which feel like small misfires...like wtf
Now getting 2c3d and 2caa codes....everything is new just days old
Help is greatly appreciated
3,640
Tell us about the car - year/model/miles - mods. Was it doing it before the updates? And for how long? etc ...
Msport335
116
26
2009 335i FBO/LSD/PS2/METH 85k miles / 136k kms on the car
prior to changing everything i suspected there were leaking injectors as afrs would not climb to 234.95 when i let off throttle and was also having light throttle stuttering around 3k rpm (which was most likely a number of small misfires like your driving over a very bumpy road)
so i proceeded to replace everything , index 12s, coils, plugs, 4 Bosch o2 sensors and BMW lpfp sensor. hpfp and lpfp are running perfectly fine at idle, cruising and wot pulls so no concern there.
car started having rough cold starts after all the new stuff was installed and threw coldstart misfire codes in cylinder 3&4.
i swapped coils to see if misfires followed....they did not.
i then proceeded to replace the brand new injectors in 3&4 with older index 12s in working order. next morning coldstart was fine ...no misfire in 3&4 however now misfires in cylinder 1&2.
so i swapped out the new plugs in 1&2 with a couple old plugs i had which were in good shape (all NGK 95770)
next mornings cold start was ok....no misfires but still stumbling a bit.
this mornings cold start was the same as well...drove to work...all ok by the looks of things. drive home from work and all of a sudden notice bank 1 AFR stuck around 20:1 and stft1 froze at 0. cleared codes while driving and they came back shortly after (did this again over and over till i got home)
Msport335
116
26
what points to a vacuum leak?
vacuum at idle is normal and boost builds just fine during pull
Msport335
116
26
here's a log with everything new installed ....just yesterday got 2c3d and 2caa codes
https://datazap.me/u/msport335/94-octane-pure-stg2-v2?log=0&data=3-22
just swapped out bank1 pre cat o2 due to the codes from yesterday and pulled a few logs... also put the brand new injectors back in cylinders 3&4. noticing the AFR's in a couple of these logs don't hold steady at 234.95 when i let off....they start to fall back down again..... keep in mind these are brand new index 12s from FCP euro which were installed last week.
any ideas?
https://datazap.me/u/msport335/pure-stg2-94-octane-v2?log=2&data=3-22
Maximum96
31
18
Check all pins in DME connectors, I remember some one had exact problems and pins were pushed in
Msport335
116
26
I'e never even opened up the DME....how could the pins be affected. Do you mean the connectors off the wiring harness that plug into the DME?
Msport335
116
26
Stumbling cold start this morning but no codes. I have a suspicion that a couple of these brand new injectors are leaking but I don't know which and that' causing the rough cold starts and causing the afr's not to shoot right back up to 234.95 when I let off throttle....sometimes it does but sometimes not. Do I say F it and reorder 6 new ones from fcp and send these back to them?
4,348
you could try pulling the injectors and doing the starter test with injector harnesses disconnected
Maximum96
31
18
It's a great test, but I urge to replace injector seals after that, and replace it with the proper procedure, I did not know that and caught it quick enough not to bore out my injector hole from a burned up seal!
Msport335
116
26
Is this test legit ? Cuz I just left my new injectors in the head and tested my older index 12s this way by unplugging injector harness and coils and cranked it over a number of times...... surprised that o didn't see one of them leaking ......fairly certain I got the procedure right. As i was cranking, there was plenty of pressure according to fuel rail pressure monitor via mhd. No leaks .... y did I purchase new injectors of my old index 12s look to still be good... maybe it was o2s all along?
  • Sad
Reactions: Maximum96
sometimes a super small detail that was missed will produce headaches.
1. when installing injectors - did you install each one in the bore hole within 30 seconds or less after taking off the cap?
2. after taking off the cap, did you also push the injector into the smallest o-ring containment hole on the injector tool in order to compress the seals even more than the published amount? If this was done, then the injector(s) should have seated into the engine fairly easily with very little effort.
3. was there any resistance that was beyond "normal" resistance when inserting the affected injector holes? if so, did you make sure that the injector was absolutely seated fully on those holes?
4. was there a lot of gunk in the area immediately surrounding the injector bore holes upon removal of the injectors? If so, some debris could have been caught between the borehole walls and the new injectors.
5. Was there any oil in the injector area where each came out?
6. the bendable braces were reinstalled with correct orientation? where the bolt forces the bended part against the injector base to keep them perpetually braced downwards?
if all were done, then could be a vacuum leak as previously stated.
Reactions: Xm-n54 and Jeffman
