New boost control XDF tables
all4bspinnin
178
98
135i TT
Also, correct me if you guys found different but the high and low range on these tables are 0.000 to 2.032
RSL
503
0-1.999999991808 per DAMOS conversion, but the conversion you use, how many decimal places or rounding off determines what you will see in xdf. Hex is the only true value. Converted values may be marginally different in xdfs if everyone uses slightly different conversions, but FFFF is the real max (unsigned) no matter what decimal value it's converted to.
all4bspinnin
178
98
135i TT
I originally set it to FFFF and saw 2.0. I got curious and extended the high range to 100 for the table and put arbitrary value in. I put a 5 in one of the cells , saved it and opened the table back up and it showed 2.032 (999A). We'll never run a value like this but i wanted to see what it would show. Perhaps you hex guys can educate.
RSL
503
Something went wrong if you're talking about that happening on divisor tables. If a 2 byte FFFF is converted to be equal to 1.9999, you coud put 1,000,000 or 5 in the xdf and it will max at FFFF value no matter how high the xdf limits are set. 999A = 2.032 would be a conversion of about 0.000051676. Correct factor on the divisor Z cells is 0.000030517578 or 0.000031 for short.
Conversion rounding output differences:
FFFF * 0.000030517578 = 1.999999991808
FFFF * 0.00003052 = 2.00015872
FFFF * 0.000031 = 2.031616
That last one would be 2.032 when limited to 3 places in TP, exactly what max hex would be and exactly what you said you saw. If the conversion in the definition you have is 0.000031, either the hex wasn't accurately displayed or you accidentally looked at a different cell/table, but the conversion value you was correct for FFFF.
Reactions: all4bspinnin
all4bspinnin
178
98
135i TT
@RSL, I figured out what i did. On the IJE0S and INA0S tables above, the conversion factor for the Z data is X*0.000030517578. On the IKM0S ROM attached above, the conversion factor in the defined tables is X*0.000031.
Im wondering if we should update the conversion factor for the IKM0S ROM to make it standard across all ROM's....
Ive attached a pic with the values with an updated conversion.
RSL
503
Im wondering if we should update the conversion factor for the IKM0S ROM....
Just depends who's defining and if they truncate/round early. For me, depends how lazy I am at the time and how big the XDF is getting. As you can see above, they're all FFFF, the converted value just slightly changes depending how far out it goes. For comparison purposes, the same yardstick should be used, but difference out to the hundredths or greater isn't going to make any real world difference on these. If the XDF were limited to 1-2 places displayed, the conversion place count is even less noticeable.
If the IKM0S is 0.000031, I'll update to the full factor for the sake of matching.
Edit: changed XDF conversion.
2,271
817
so how does the Ikmos 1M ROM deal with the potential detonation caused by the faster onset of boost?
First the throttle delay table and now this.
It’s yet another reason why I want it IKMOS ROM for my car :)
This table will not effect the spool speed at all since typically people have their wastegates operating at the WGDC ceiling during spool.
2,271
817
Whats interesting about this is the 1M's did always spool much faster than other ROM's. This is probably one of the reasons. I need to look at it further
Edit, i pulled an IKM0S ROM and took a look at it. Definitely different.
Edit 2: I just realized RSL posted the picture of the 1m ROM already. Sorry for the double pic
Also, on a side note... be careful using these 1m values. The car will make 19+psi extremely quickly at lower RPM. You may run into a situation where the car will see knock due to the rapid onset of boost at really low rpm.
You can see why Im confused here. @all4bspinnin is saying that by using the 1M values the car will make 19+ psi extremely quickly.. whereas you’re saying regardless the values are maxed at spool. Who should I believe ?
That's because often people conflate information regarding tunes. This is seen a lot with tune reviews, it's been that way since the Procede vs JB3 days.
You can see it with the MHD OTS maps. Wedge will make some minor changes to a map and release an update, changes that will likely make no discernable difference. People will then start posting threads about how much more or less power their car makes based on scientific measurements like the famous butt dyno or by how much wheels spin they get or even worse all the comments about how "smooth" everything is. Then people start to correlate other peoples misinformation with their own set of unrelated problems and the spread of misinformation snowballs into superstition. Look at all the threads about the burble mod causing turbo damage for instance.
In reality there's four things that will make a difference in the tune relating to spool speed. Timing, WGDC, VANOS and fuel. So unless you've changed any of those factors your not going to spool any faster.
all4bspinnin
178
98
135i TT
Tough crowd in here lol. Im not the best at explaining things over the net sometimes.
What im trying to say is the 1m allows for the car to have a higher boost target ceiling at a lower load potentially due to those tables... I need to test to confirm. On the i8/Ij/In ROMs, you'll get a boost target dip like in the first post of this thread. That dip isnt present on a 1m allowing it to hit higher boost levels earlier without throttle closure.
Ive had a 1M make 21psi in only 300 rpms going WOT at 2396 RPM. I cant remember another ROM ive tuned that allowed that much boost at such a low rpm. All other factors were the same - wgdc, PID, load ceiling, fuel, timing, and vanos, etc. Again, I dont advise loading the car up at that low of an RPM. I'm just sharing an observation from experience.
The cause of restricted boost targets at lower RPMs will be caused by volumetric efficiency tables. The 1M has lower values in the Boost Request Offset table which is probably what allows you to target more lower down. Same story with the other high output N54 bins.
all4bspinnin
178
98
135i TT
On the car im referring to, the BRO was set the same as the others.
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
Get the decimal places out of here and use X/32768 :)
RSL
503
I've been lazy, but would save a lot of space and any conversion variation. I'll go back and do a find/replace on all multis at some point.
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
Yea I always do a check if there is a division that gives a cleaner conversion vs. multiplication. Sometimes there is not, but a good majority have one.
Reactions: RSL
