Need VO code for door chime pls (other common codes welcomed as well)
Danksies
181
55
NoVA
Looking to code out a couple annoying things in the car and for some reason my FSW-PSW.MAN doesn't show "CC_ZUENDSCHLUESSEN" which is the chime for key in ignition when you open the door. Does anybody happen to know the VO/FA code needed to add it to my VO?
On a slightly separate note, if there are any other VO codes you guys think are worth adding/changing post those up as well (And yes I've gone through the 1000+ codes in the Reference Option Code List loool)! Thanks
BimmerGeeks!
15
16
Bmw
There isn't a VO code to remove the door chime. Are you sure your pulling the trace file from your KOMBI? Looking through all versions of E90 KOMBI variants I find CC_ZUENDSCHLUESSEL as an options.
Danksies
181
55
NoVA
That's weird, I'm using an updated FSW-PSW.MAN file from like 2014 so it should be there. Just every time I read the ECU and look for CC_ZUENDSCHLUESSEL nothing shows up. Is there like an updated DATEN file I need to update or something? lol
BimmerGeeks!
15
16
Bmw
What do you mean your using an update .man file from 2014? You read and edit the .TRC file & write the .MAN file. The file should be read directly from your KOMBI module. Email me your trace file from your KOMBI to [email protected]
Reactions: digitalashley
