Need help with 60 ft. times
Ivhadenough
09 BMW 335i
can't get better than 2.21 60 ft times....09 full bolt- ons, XHP flash tool, MMP stage 3 turbos, AEM water/meth injection, 625 whp HELP? Brake boost won't go above 2500 rpms
Silent11
124
86
2007 Bmw 335i
you have 625 WHP, you better have drag radials if you want sub 2.0 60 foots, and you dont need to go to 2500, ive had better 60 foots at 1500 - 2000
typedRew
412
221
2009 335i xDrive
2.2 because youre spinning or because you cant find any power?
tisdrew
179
91
09 335i 6MT
What rear suspension? LSD and diff lockdown? Stock control arms? Rear tension rods? Motor/trans mounts?
Also I've heard it's hard to launch the auto but you should look into it. Are you spinning or bogging?
Reactions: Ivhadenough
Ivhadenough
09 BMW 335i
I'm running Mickey Thompson drag radials, I'm not spinning, I'm not building much if any boost when I power brake it (hold brake and gas) just wondering if there's a trick. Yes I'm turning DTC off too. Thanks guys for any insight
Silent11
124
86
2007 Bmw 335i
whats the psi for the tires ?? 17-19 psi dead hooks for me and my 6AT doesnt like it so it goes into third... 20 psi lets me spin a bit and hook with 1.8 60 foots on MT ET Streets
