E9X N55 Built Motor
ap485
74
55
Houston, TX
2011 BMW E92 335i
Hello folks!
I'm new to spoolstreet. Actually, this is my first post in here.
I thought it's a good time to share my build. We have here probably the first N55 full build motor. The project still in the works. All the work has been done by ABR Houston. They have done an amazing job so far. The build motor includes closed deck, ported and polished heads with Ferrea valvetrain.
Here is pic of the small block:
Here is the cylinder heads:
Also, I'll be installing Big Boost 3.4 Turbo kit.
The car still Auto for now. I still debating in between upgrading to a full build Propulsive Dynamics AT or DCT swap.
More pictures to come stay tuned
Sbrach
224
175
N55 DCT E82
Awesome project. My vote is DCT swap but maybe I'm biased lol.
Reactions: N55uk
ap485
74
55
Houston, TX
2011 BMW E92 335i
While we wait for the crank hub. I decide to work on the transmission.
I was debating in between getting my AT build or DCT swap. Like most of you know, the DCT swap is pretty expensive. For that reason I choose to build my current AT.
BTW, Propulsive Dynamics is not doing the AT builds anymore. They’re just selling the upgraded clutches and bushings.
Anyhow, I talked to Alex@ABR about it and he didn’t hesitate to do the work. So far, I got PD clutches and bushings.
Also, all trans internal parts (input shaft, basket, etc) has gone thru deep cryogenic process to increase strength and durability. Thanks @nitemare for the tips.
Today, I received the torque converter back from TCR. They increased the stall to 2800-3000.
Custom trans oil cooler is next.
Tippin
89
49
View attachment 10178 Also, all trans internal parts (input shaft, basket, etc) has gone thru deep cryogenic process to increase strength and durability. Thanks @nitemare for the tips.
Funny story on the PD discs.... you must have been one of the 2 people who bought last Thursday or Friday. I bought the last set of discs from Jason friday night and as far as I am aware he has no plans to make more. So consider yourself lucky haha
ap485
74
55
Houston, TX
2011 BMW E92 335i
Well, I bought those clutches back in January. Wow! No more PD:astonished:
hardparker
80
33
f25
So, is anyone making clutch upgrades for the 6HP, then? If not, you should get thickness measurements on all of the steels, at least. One of us could KickStarter a batch later, if needed.
Hey, ap845, what are you planning on doing for fittings to the trans and what cooler? I bought some of these fittings off of eBay, a Derale 25792 thermostat and a B&M 70274 cooler that I'm going to put on for my X3's 8HP. Those 3,000 RPM AWD launches and 1/4 mile runs aren't particularly nice to the fluid in terms of temp.
ap485
74
55
Houston, TX
2011 BMW E92 335i
PD was the only one I know that was doing the upgrade.
I'm planning to tap into the OEM trans cooler lines using the Vader Solution trans fittings. For the cooler, it will be a Setrab 25-row and FSM-165 thermostat. I'll add pics of the whole kit later.
ap485
74
55
Houston, TX
2011 BMW E92 335i
Here is a pic of the trans oil cooler parts for now. I’m not sure if I might need more fittings at this point. Anyway, I’ll know soon.:)
Here is the part list so far.
Setrab Oil Cooler 50-625-7612
Setrab M22 to -8AN Male Adapter, 90 Deg (I've an extra pair, selling it for $40)
Improved Racing Thermostat FSM-165
Russell -10AN Twist-Lok Hose (10 ft should more than enough)
Vader Solutions Trans Fittings -8AN
Russell Straight -8AN Twist-Lok Fittings
Russell 90 Deg-8AN Twist-Lok Fitting
Russell 45 Deg -8AN Twist-Lok Fitting
