Hey guys, I'm a bit baffled regarding the current state of my N54. I'm reading 0 psi in cylinder 3, and I mean you would think the gauge is stuck. Not even the slightest flutter. I checked the adjacent cylinders and cylinder 1 as a benchmark, and they were all normal, within 2psi of each other.
The strange thing is that I took it out for a nice little drive, nothing crazy I don't go super hard with it, and parked it in the garage, all good. Logs look good. Next time I go to start it- it's stumbling, running like **** and wants to die. throws misfire cylinder 3. Now at this point since it ran so well literally the last time I drove it I'm thinking it's got to be a leaky injector that finally went to ****, a mosfet or some sort of ignition problem. I troubleshot all of those things first, systematically finding they weren't the culprit. Coils good, plugs good. I even have msd81 and I checked mosfets (I know I'm an idiot msd81 doesn't have the same mosfet problem).
So even though it seems unlikely to be something mechanical inside the engine i figure I should do a compression test.
0 psi cyl 3.
No oil in coolant, however I haven't drained oil yet to look for coolant in oil. I confirmed the piston is moving inside the cylinder.
Car is basically fbo, pure stage 2, however I only run about 18-20 psi max with e30. I've been holding off on going more boost until I upgrade fuel pump. What the heck.
I guess next thing would be to do leakdown test and my friend is gonna let me use his fancy snapon inspection scope. Bummer.
Any guesses or similar experiences?
0 psi cyl 3.
