N54 tuner ?
N54Lars
Belgium
E91 335i MT
I really don't know wich tuner i should go to i i my setup :
7,5 inch intercooler
Hydra hp650's in and outlets
Full exhaust
Stage 2 lpfp only DI
I'm from belgium car is orginally from germany and running a custom mhd map around 18-19psi i'm thinking of getting 102 octane pump gas from germany of running a e40 mix, don't know it's going to producte that much more because of stock hpfp and guys running 21-22psi on pump gas with these turbo's, so wich tuner and 102 of e40 ?
SlowE93
1,832
Just a plane ticket away !
E93
Full exhaust
If you are staying DI only...probably 102.
If you are willing to upgrade fueling...ethanol blend HANDS DOWN.
seb.apprenti
278
135
reunion island
335 i e92
Full exhaust
I have almost the same setup as you, except that my fuel is sp95 (eur)+WMI
I entrusted the adjustments to ken wedge performance and I live on Reunion Island
Slowagon54
207
96
Dont think its worth to go the extra mile to germany to get the fuel you need for your car. Is it your daily? I would use the best gas you can get in your country and top it with WMI (its really not that complicated) or Ethanol in case you want some freaking numbers. :)
