N54: The best Plugs, Injectors and Coils Thread
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
What's posted on the website
Eldor is equivalent to the Delhi 153
Single turbo cars such as my old one and my new setup will be running Delphi 153 with NGK 95770 plugs (5992 equivalent) but I don't think they last as long
Good to know thanks. I may try the eldor out just to get some first hand experience.
foe516
80
15
rockauto for all your plugs and coils. all day every day.
GN10571 24$
NGK 95770 $9.50
NGK 97506 $13.50
with 5% off coupon and very reasonable shipping
b1mmr
110
32
First off, this thread was a great idea and thanks to those who have taken their time to contribute to it. This thread will be a great reference point for newcomers and tenured people as well.
I had to grab a Delphi coil not long ago without much notice and ended up with a GN10328. Worked flawlessly but I will check out the other options eventually as I need to replace the rest. You can see this coil side by side with a Bosch here.. View: https://instagram.com/p/BLRqfPmgtKd/
1,630
Getting back to injectors...
I still have my original injectors on my 2008 335xi / 60K miles. I think I'm lucky...they still seem fine, no major hiccups. When do people usually change injectors, and what symptoms tell you it's time to change them?
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
I sell rebuilt index 12s with decouplers and seals for 550 shipped , let me know ... sorry for thread jacking ... let's keep this about plugs and coils
Reactions: WhoLV
1,630
That's good to know, Omar. But I will happily by new OEM injectors when needed. My question is when do people usually change injectors, and what symptoms tell you it's time to change them?
Narcosis
150
87
Hudson, WI
F82
A "colder" spark plug is more efficient at transferring heat from the firing tip to the engine head. In doing so the firing tip of the plug is kept cooler, helping with the elimination of detonation / pre-ignition.
Milan
413
241
jebi se
your mom
So talking to my big hp buddies 1000+ and their tuners they are adamant on running stock heat range even with E85, at most one step colder i.e. Ngk 95770.. do we know of any plugs other than the OE Bosch ones with their heat range that'd work?
I personally agree with this. I made right under 1000 whp with 0.5 steps colder than stock on my z06. I do not believe in colder plugs with e85. I need to get my new car on the dyno and test some stuff.
Reactions: mkster08
mkster08
107
19
Kansas
Let's find some plugs :)
