N54 Record Books
Cmiggz
42
13
2008 ST 335i
Does vargas have the 1/2 mile at 173.68? Im curious who has it. So i know what to shoot for :)
pipe7284
31
E92 335i 6MT
Dynojet numbers:
PTE6466 on stg2 lpfp ONLY.....677whp at 22psi
PTE6466 on stg 3 lpfp and vtt double shotgun 730whp at 26psi
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Dynojet numbers:
Good numbers but power records should only be by turbo size nothing else.
There's a lot of variables for supplying the fuel for a given power level, not to mention you aren't limited to one fuel type.
If you divide it up by fueling you'll get a bunch of "records" - 6466 E85 PI, 6466 E85 double shotgun, 6466 93 + meth, 6466 MS109, etc etc.
yuli8466
99
23
Dynojet numbers:
did you mean, stg2 lpfp only, with out meth and PI ? so what kind of fuel gas ?
thank you . hope could reply in details , i am doing same single
SJ_1989
368
299
Illinoisssss
2008 E90 335i
I going to make my own class. Going after the quickest 1/4 mile stock 6MT gear shift knob record.
Seriously though. I'm new to this forum and seems to be a lot more info here than where I came from (and I've been MIA for awhile so that doesn't help). Do any of these records meet say NHRA/IHRA or other sanctioning bodies rules based on their location and times they are running for drag racing? It doesn't matter whether they are or not and I'm not discrediting anyone's times, a 9 is a 9 and a 10 is a 10.....just genuinely curious as it takes a lot to become legal from an NHRA/IHRA perspective for someone running 9's or 10's.
2,198
I thought you just had to make your run at an accredited track with official timing equipment etc? Which is why people question the middle east times as the track, iirc, is not accredited. Which makes their records suspect.
mao76
bmw 330d
hi I'm new to this group, I'm a bit inexperienced, I could know a n54 that holds without opening the engine having a certain margin of reliability? I would have over 600hp
SJ_1989
368
299
Illinoisssss
2008 E90 335i
Not sure. This is new to me but the domestic guys seem to put a lot of time and $$$ meeting regs even if they aren't competing. Either way, doesn't matter to me. I'd rather make sure the ASSet along for the ride is safe so an NHRA approved cage is getting installed next month.
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
Ill be going for that title this year as well @SJ_1989!!! Best of luck to you!!
Going to try to do it with all bmw parts as well, no 8.8 swap! Goal one day is to run a 10.5 one day with it on stock motor and trans
Reactions: fmorelli
135boost
250
Finland
135is
i think 312kph @ standing mile is close to record too with stock n54 internal and stock internal 6at
LaserBimmer
West Virginia
2008 335xi
Got my car into the 10s. Quickest xdrive e9x. Wasn’t sure if I just posted here or what to get on the 10 second list. Thanks in advance for any info.
2008 335xi with V1 mmp stage 3s at 25psi and helix 4x running e85. Tunes by David Shoup and Rod Sutphin.
