N54 Oil Catch setup Help
Bimmerny
30
Currently i have a vadersolutions second gen Vta setup going to one can which i do not like and is causing my negative crankcase pressure to be low.
Essentially i am thinking to do a closed loop system similar to OEM. My thoughts are to run two separate radium engineering cans. Check valves on both (unsure if i should do one way or adjustable check valve)
I was thinking to recirculate the Low side to the BMS throttle body adapter port and high side to be closed. What are your thoughts?
Currently is on stock Valve cover, stock twins, Fbo but soon to be single turbo
florida2002m3
12
I would be concerned about too much crankcase vacuum when closing off the high side. Stock flapper has a small hole in it to relieve vacuum even when the flapper is closed. So deleting the stock flapper and using a check valve will require some sort of vacuum relief valve. Too much vacuum and your engine seals will start singing to you.
turbohugh
64
15
E92 335
I haven't blocked my head ports yet. I'm running a BMS TB adapter to a low side catch-can. I'm recirulating my high-side [removed the flapper slipped a 1 inch hose over the fitting] to a catch can and back into my rear turbo inlet [using the diverter valve port]. Front diverter valve blocked off and typical BOV setup on the charge pipe .. Good vacuum at idle and no issues on logging pulls.. YMMV .. Im using the BMS check valve/catch can adapter in the low side. Both of my cans are catching oil and I don't smoke or anything at idle or startup. Shoup tune with Motiv + PI
Reactions: Bimmerny
