N54 idle surging and no start unless jumped
Matthewhernandezz
what’s up guys my 335i recently just stopped turning on and only turns on if jumped. When it starts up the idles surge between 1k-1500 rpms I’ve replaced the throttle body,checked fuses, any intake leaks. still nothing. Took to 2 different mechanic and no one knows the problem. Water was also in the battery tray fyi
NoQuarter
1,596
993
Indiana, USA
Z4 35is, 535xi, X5 35i
Focus on the need to jump start it.
New battery and it still requires a jump.
intake leaks, etc are not going to help here I don't think.
157
Are you sure your inlets are fully seated onto the turbos with no cracks in the piping ? A new battery and still needs to be jumped is very concerning. Do you have any exposed wiring that may be causing a parasitic drain?
bob20124
2011 Z4 35I
Bad battery ground? Are you jumping under the hood at recommended terminals?
Tedbuildiy
209
40
So you have to start somewhere.
if it doesn’t crank at all without being jumped and the battery is charged, what can cause that?
Faulty key ? Can’t be that as you say it can be jumped with leads
could it be a fuel related issue?
camshaft sensors can cause peculiar errors...
Do you have any software to see if you can pull some codes from the DME ?
