FS N54 Custom ST bottom mount kit
Status
Not open for further replies.
gixercho
54
42
E92 335i Custom ST
Hi, i will put for selling my custom ST bottom mount kit next month if someone want to upgrade his car with top quality ST kit with one of the best turbos on the market. The turbo is Owen Developments ODGT3582HTZ Mspec with Tial .82 Vband SS housing on 600miles from full check and revision by Owen. Mspec means that it is with full list of upgrades Owen can provide, metal bearing cages, thicker heats shield and many more and costs 3000 USD(not a cheap Precision or Comp turbo). The kit will be without wastegate and may be coolant pipe and the block fittings, but stock are easily for modify to do the job. I am located in Europe. Price is 4000USD. Pictures are from when the kit was brand new. There are modification on the hoses with better ones.
R.G.
668
326
Henderson, NV
E92 335, F10 M5
Actually a pretty slick looking set up. I like the water cooling lines to the WG. Mani should perform, GLWS
gixercho
54
42
E92 335i Custom ST
Hmm ill try to take a pic of the intake how is it on the car, i dont have one on the gruond.
devildog0905
78
29
2007 BMW 335i E92
How many miles on the kit? Do you have any logs or dyno results with the kit installed? Why are you selling it?
gixercho
54
42
E92 335i Custom ST
Around 22000 miles, turbo itself now is on 600miles, 562whp dynojet 93 octane pump gas only 23psi and HPFP was maxed. The car is only with stage 2 lpfp, we do not have e85 here and i dont want to bother with meth, with proper fueling limit of the turbo is.around 740whp and of the kit alone much more. Ill send logs and dyno graph after i get home. I am selling it because i am starting to build short runner bottom mount twin scroll kit with borg efr turbo.
gixercho
54
42
E92 335i Custom ST
Logs are not with the latest flash and are in very hot ambient.
  • v21.csv
  • v21-2.csv
  • v21-3.csv
  • v23.csv
gixercho
54
42
E92 335i Custom ST
3800USD, 200usd lower price, because ill leave the wastegate for my next build
Status
