This is going to be a living thread where I'll attempt to list several categories of mods as well as the various brands which are actively being sold. I'm going to fill this out as I find time. Please post up any mods that you think should be on this list, or mention any mods which are no longer produced or supported. Prices are not included, as they may change frequently.
IF THE MANUFACTURER HAS A KNOWN ONLINE PRESENCE BUT IS NOT ACTIVE OR DOES NOT HAVE AN ACCOUNT HERE THE PRODUCT ISN'T DISPLAYED!
Intakes and piping
[TBODY]
[/TBODY]Intercoolers
[TBODY]
[/TBODY]Exhaust
[TBODY]
[/TBODY]Turbos
[TBODY]
[/TBODY]Fueling
[TBODY]
[/TBODY]Tuning hardware/services
[TBODY]
[/TBODY]Engine builds/mounts
[TBODY]
[/TBODY]Cooling/reliability
[TBODY]
[/TBODY]Drivetrain/braking/suspension
[TBODY]
[/TBODY]
Intakes and piping
VRSF DCI | Fits all N54 | @[email protected] |
VRSF Inlets | Stock location silicone, relocated silicone, relocated SS kits available | @[email protected] |
VRSF Charge Pipe | 2 1/8NPT bungs, OEM DVs, Tial, or HKS flange | @[email protected] |
AD-E Charge Pipe | 1/8NPT bung, Tial flange, various colors available | @AD-ENG |
VTT Inlets | Stock location silicone, stock or upgraded turbo fitment | @[email protected] |
VTT Outlets | Silicone outlets, various fitment options for different intercoolers | @[email protected] |
Precision Raceworks Inlets | Silicone relocated kits, stock or upgraded turbo fitment | @PRECISON RACEWORKS |
VRSF Intercooler | 5" stepped street, 7" street, 7.5" race | @[email protected] |
AD-E Intercooler | 7.75" stepped, supports 650hp, pre- and post-core 1/8NPT bungs | @AD-ENG |
VRSF Downpipes | 3" Catless DPs, various fitments | @[email protected] |
VRSF 3.5" catback | 3.5" street catback for 335i | @[email protected] |
AD-E Single Turbo Kit | Bottom mount, various PTE ball bearing turbos available | @AD-ENG |
MOTIV Single Turbo Kit | Bottom mount, various FP and Tial XONA turbos available | @MOTIV Motorsport |
Arsenal MSE Single Turbo Kit | Coming soon for E9x | @arsenalmse |
VTT Hybrids | Stage 1, 2, 2+, 525-675whp options | @[email protected] |
VTT Stage 3 | Twin Garrett turbos, GT series for VTR kit, GTX series for VTX-R kit | @[email protected] |
VTT GC series | Stock location, 700whp for GC Lites, 800whp for GCs | @[email protected] |
AD-E Port Injection kit | 6AN lines/rail, available Bosch injectors | @AD-ENG |
AD-E Walbro 400 Fuel Pump kit | Plug and play Walbro kit, no butt connectors required | @AD-ENG |
VTT Shotgun Single Barrel | Relocates stock HPFP to be overdriven by accessory belt | @[email protected] |
VTT Shotgun Double Barrel | Adds second pump to Single Barrel setup | @[email protected] |
MOTIV Port Injection kit | Includes Bosch injectors, optional upgraded fuel lines | @MOTIV Motorsport |
Fuel-It! Stage 1 LPFP kit | Adds inline pump to factory LPFP setup | @Dave @ Fuel-It! |
Fuel-It! Stage 2 LPFP kit | Replaces stock LPFP setup, available to fit stock bucket or bucketless | @Dave @ Fuel-It! |
Fuel-It! Stage 3 LPFP kit | Replaces stock LPFP setup with dual aftermarket pumps | @Dave @ Fuel-It! |
Fuel-It! Stage 4 LPFP kit | Replaces stock setup with dual pumps, replaces restrictive lines/fittings | @Dave @ Fuel-It! |
Fuel-It! Direct Port Meth injection | Manifold spacer with injectors, various controller options | @Dave @ Fuel-It! |
Fuel-It! Port Injection kit | Manifold spacer with Bosch injectors various installation/controller options | @Dave @ Fuel-It! |
Fuel-It! Throttle Body Injection kit | Throttle body spacer, various installation/controller options | @Dave @ Fuel-It! |
Precision Raceworks Stage 2+ kit | Replaces stock LPFP with one pump with a modular, upgradable system | @PRECISON RACEWORKS |
Precision Raceworks Stage 3+ kit | Adds second pump to Stage 2+ kit | @PRECISON RACEWORKS |
Precision Raceworks Stage 4 kit | Adds third pump to Stage 3+ kit to support up to 1500whp | @PRECISON RACEWORKS |
AD-E 5bar MAP sensor harness | Allows use of additional 5bar MAP sensor, retains stock sensor for IAT | @AD-ENG |
MOTIV | Protunes for N54 cars | @MOTIV Motorsport |
Arsenal MSE | Protunes for N54 cars | @arsenalmse |
MHD | Tuning software for Android devices, includes customizable OTS maps, logging, and custom map flashing | @[email protected] |
xHP TCU Flash | Flash for 6-speed auto TCU | @RayBan |
Fuel-It! Bluetooth ethanol analyzer | Ethanol fuel sensor, compatible with various tuning solutions as well as displaying content on Android/iOS device | @Dave @ Fuel-It! |
ABR Houston Engine Builds | Various engine building options | @[email protected] |
MOTIV Engine Builds | Various engine building options | @MOTIV Motorsport |
Arsenal MSE Engine Builds | Various engine building options | @arsenalmse |
Arsenal MSE Heads | Stage 1-3 available, with or without core | @arsenalmse |
VAC Motorsports Heads | Stages 1-3 available for N54 | |
AD-E Urethane Engine Mounts | Fits 135i/335i | @AD-ENG |
MOTIV Solid Engine Mounts | Solid mounts for N54 engine | @MOTIV Motorsport |
AD-E Oversized OCC | High capacity, two AN inlets, single AN outlets, multiple installation possibilities | @AD-ENG |
MOTIV Oil Cooler Adapter | Allows for custom oil cooler installations, deletes thermostat for track use | @MOTIV Motorsport |
AD-E Rear Drag Brake Kit | Allows for rear drag wheels as small as 15", fits 135i/335i | @AD-ENG |
MFactory Limited Slip Differential | Limited-slip rear differential for 135i/335i | @MFactory |
MFactory Carbon Fiber Driveshaft | @MFactory | |
Brembo | 6-piston monoblock front, 2-piece 4-piston rear | |
StopTech | 6-piston front, 4-piston rear |
