Found the purchaser and the order was for non-optioned Classic RB's from June 2015 so likely always has been on stock inlets (unless some were equipped thereafter??). These units would've been in-house VSR balanced to some very nice sub .2g levels to around 175,000rpm.
If they need refurbishment you will definitely want to add on the High Flow inlets (consider them mandatory for all upgraded turbos) and High Flow oil drains (highly recommended). You'll also want to ensure you've done the larger vacuum reference modification for the BOV and also confirm it is properly adjusted, assuming one is equipped. And also of course run high quality oils, possibly even race oils, pending on the intensity of your usage patterns.
Our recommendation is to initially try the easy stuff first such as the PCV valve (or move to the external PCV kit), vent hose, valve cover gasket, and inspect the valve cover closely for cracks while removed (or replace entirely). Flaky DI Fuel Injectors also can cause smoking while also breaking down oils quickly, while potentially washing out rings and/or contaminating oil (which wreaks havoc on everything especially the turbos).
All of this stuff are some things to keep in mind, some of the causes to effects as stated above. Ultimately if you want to cut to the chase you can check the turbos shaft play (primarily axially)- this requires dropping the downpipes- but do not disregard the potential causes regardless. Sometimes it's the simple things that are overlooked that cause the same results.
Any other questions feel free to shoot us an email, we are not difficult to reach in that way.
Thanks,
Rob
