MMP Stage 3 won‘t hit boost target
MIT_N54
Hey guys, got a problem with my 335i N54 with MMP Stage 3 turbos.
Modlist:
- MMP Stage 3 Turbo
- VRSF Inlets
- 7“ Intercooler
- Phoenix racing CP
- RS6 diverter valves (new)
- N20 Map (new)
- Silicon inlets
- Upgrade PCV
- OCC
- new boost solenoids
- Custom tune in the making right now
- silicone vac lines
Car wont boost over 18-19 psi (log attached) and it throws the legendary 30FF code while under WOT. I checked boost piping und vac lines but i couldnt find any leak or something. While building boost I think i can hear some compressor surge too.
Logs atteched
I hope some of You guys can help me out
  • 2022-03-20 16_54_38 I8A0S VC30729_N54-MMPS3_100ron_B4R0.6.mhd.csv
MR-KRAKA
85
You either have a boost leak or need your vacuum lines to WG checked out/replaced. After that look into you boost control solenoids. You should also make sure your WG arms are closing at spec with vacuum. Those turbos are working way too hard to get 20psi as is.
Edit:
I didn’t see you have all new bcs and vac lines. May also want to look in the possibility of inlets collapsing or your new diverters acting up. Those could explain the noise
The money pit
9
Edit:
i just checked rear inlet i believe is collapsing i pulled it off just to the front of the lip so its still somewhat covered heres the log
NoGuru
1,213
Just North of Detroit
BMW 335is
It's taking so long to build boost. If you think its an inlet collapsing I would not do many more pulls. I had a new set of turbos blow due to the rear inlet collapsing. Make sure it does not have any kink in it.
The money pit
9
So I went under there a took about 4 extensions and pried it off just a bit it has been hitting boost but now I need to either order a completely different brand of inlet or try and figure out how to make this one work
