MHD - No Exhaust Burble?
squeedle
19
SF Bay Area
2009 135i AT MSport Coupe
Just flashed my N54 AT 135i with MHD for the first time. I used the Stage1 91oct map. In the options, I selected catted downpipes (which I have) and exhaust burble to 1sec/1sec and "soft". Didn't hear any burble. Upped it to 1sec/1sec "hard", still nothing.
Is this a feature that only works with catless downpipes or something?
Clean WHP
173
136
2010 135i Msport 6MT
not sure, but I know an aftermarket / louder exhaust exaggerates the burbles. My car is on 1 sec soft with a BMR 3.5" full exhaust and VRSF catless downpipes so it definately is a loud exhaust, and the burbles are pretty loud even just on soft
I've never played with those settings and I'm catless so I can't really help you out there, sorry. Your cats may just be doing a good job. I'd tell you to turn it up more if you can but I don't want to be the reason you blow your cats out, lol
Reactions: Clean WHP
squeedle
19
SF Bay Area
I tried it at "soft" (2nd lowest setting) and "hard" (highest setting). So there's nowhere more to turn it up. :) I disabled it at the end because it was doing nothing and I'd rather not waste fuel or risk anything funky happening until I figure this out. Does MHD offer any support?
1and1
65
35
Tally, FL
The sound is barely audible with the stock exhaust. I ran a berk street axleback on my '09 135 with an AT and the burble was very noticeable. When I switched back to the stock muffler the sound was so hidden I finally just switched off the burble option.
Nov 14, 2016
651
262
North Wilkesboro
Often for the first couple drive cycles after flashing a new map, it will not do any burbles on mine as well. What I would do is re-flash the map, do a complete drive cycle and then see if you can get some burbles when letting the revs idle down from like 3500 - 4k.
Also, whenever you do check for codes or anything like that is your Evap completing?
Reactions: squeedle
Bmac
77
34
Great White North
I'm catless and no burble here as well. No matter what I tried it didn't sound any different than stock so I ended up just disabling it as well. When it was released there were 1 or 2 other people in the same boat. I don't think anyone ever understood why.
08_335i
371
215
2008 ST 335i
I've found on mine anything under the most aggressive and at least 2 seconds I don't get anything out of it.
squeedle
19
SF Bay Area
Interesting, I'll probably just leave it off then. That's too bad, because I do love the sound, but I don't want to go catless or buy an exhaust which will do nothing except for possibly sound louder.
Duplicities
24
E90 335i FBO w/ Inlets (soon)
Just go catless, you wont regret it. Although I truly only started hearing the burble after cutting out my mufflers and replacing them with a 2.5" pipe.
BMWE92_Harry
62
15
N54 E92
I flashed mine and took coupe drive cycle for it to become very noticeable. I have it set to the second to the highest setting, but i am going to tune it down a bit, it gets annoying on deceleration after awhile.
-BMW performance exhaust, VRSF catless DP, MMP turbos.
