First check if your lpfp is dropping. If it is then the hpfp and pi wont be getting enough pressure.
If lpfp looks good then it may be the hpfp unfortunately. I know you said you've replaced it but a lack of rail pressure is usually the sign.
What hpfp did you get? I replaced mine 2 weeks ago. HPFP was holding 750 psi under light throttle but dropping to 300 psi under throttle and boost.
(Note this is a JB4 log. HPFP value is multiples of 150 psi. So 2 = 300 psi. 12 = 1800 psi)
After changing the pump all is good again. Now holding 1800 psi under WOT (with meth) and going as high as 2550 psi during ramp up.
There are alot of cheap copies of the lpfp. Aliexpress has new ones for as little as $150! That's probably a ticking time bomb.
I suspect there are many Chinese copies passed off as genuine.
I've seen lpfp sensors fail and when that happened the lpfp just read a fixed value but didn't impact driveability. I don't know what impact a hpfp sensor would have. It's worth replacing as they are cheap. Just see if it solves your issue.
I don't know enough about port injection to diagnose that.
Good luck.
