Lean bank 2 Help!!!
TeoN54
Spain
Hi guys!So after changing several things the car keeps throwing lean Codes in bank 2,the things that I have changed so far are
Both pre Cat o2's
All vacum lines
Map sensor ot the top of the manifold
Both wastegate selenoids
Index 12 inyectors,new spark plugs Bosch
Instake manifold gaskets and also I have cleaned the valves,new valve cover
New gasket on the throttle body
I have also cleaned the Tmap sensor
The las thing i did was cheking the wiring harness and I did not find any physical damage
It may be a problem with the fuel supply?
The car is 07 145 000 km stock no mods
https://www.spoolstreet.com/graphs/log-02-28-2021-17-24-29.5928/ Here is a log at normal driving
TeoN54
Spain
Both pre Cat o2's
All vacum lines
