Kisspoint/Touch Point adaption out of range
S5W95
E92 335i, E92 M3 G-Power
Hello everyone, I have some trouble to adapt the kisspoint of my DCT. Its fittet with a new and stronger clutch. The learning process is starting without any Problems, after around 60-70(of 90) seconds it stops with the Message "Adaption done, but values out of tolerance" if I click back there is a similar message "Finished, but kisspoint out of valid range". There are also 2 Errors which appears (5031 and 5137).
The clutch still don't work well after this procedure. Maybe someone have a solution for that, whats the problem here?
Infos about my car:
E92 335i from 2009
With DCT and N54 (MHD Stage 2+)
We just upgraded the Software to 2011/03
Here are some screens of the messages:
27836
27837
27834
27835
4,348
Infos about my car:
E92 335i from 2009
View attachment 27836View attachment 27837
Are you able to drive it at all? I think I've heard to drive it a little bit and then keep trying the learning procedure.
S5W95
I had read about aftermarket clutches having this issue but not aware what the fix was sorry. Suggests asking the manufacturer?
Yes, waiting currently for an answer from the manufacturer. Maybe I can get some Infos there.
Yes, already drove around 30-50km and gave a couple of tries.
4,348
I've heard of needing to return the clutches and try again. I think there is something about them that just puts them on the outer limits of what the learn in process can handle.
