Kirkey Race Seats e90
Dec 27, 2016
134
81
2010 e90 335i
Has anyone installed Kirkey Race Seats in their e90 car? Trying to figure out the hardware mounting situation. Post pics if you have any, Thanks
SJ_1989
368
299
Illinoisssss
2008 E90 335i
  • 17" Series 55
  • VAC floor mounts. Bought both driver and passenger mounts (they are different). I forget but I use one mount from the driver and another from the passenger for what you see in the pics. Positions the seat better with the steering wheel and pedals is what the shop told me. Don't think it's required though.
  • Kirkey seat brackets. Bought VAC ones but they don't work very well with Kirkey's.
30058
30059
Reactions: Idratherbesurfing
Dec 27, 2016
134
81
2010 e90 335i
  • 17" Series 55
Are you going to ditch the Vac brackets or just mod them to work?
SJ_1989
368
299
Illinoisssss
2008 E90 335i
I sold them to the shop doing the cage so they can use it on other builds. Kirkey brackets work the best for these seats.
Dec 27, 2016
134
81
2010 e90 335i
So did you drill your own holes in the side of the seat to mount it? If you dont mind can you post the links of products you used to make this work?
Dec 27, 2016
134
81
2010 e90 335i
Jan 31, 2017
409
860
www.hydraperformance.com
2010 135i 6MT
@Idratherbesurfing
I could if the demand is there. Trouble is, they are fixed (keep weight down to an absolute minimum), but I guess there is some leeway in where to drill the mounting holes in the seat, and I could add mounting holes into the design... These weigh ~2.5lbs per seat (i.e. per pair), and I repeat are SUPER stiff. No sense in running 8lb brackets on 12lb seats... :)
