I'll still never understand this game of slapping 900+whp turbos on these cars for 750whp.
Well I'm pretty sure his goal was 800+. It just didn't get there for a couple reasons, the timing is one of them.
What is Rocco's last name? Wondering if it's a buddy of mine from years back.I wouldn't say the car has all kinds of issues, it generally runs really well. There's been teething issues with broken wastegates, boostbox, and R8 coil issues initially but they were resolved by a very motivated owner and a great mechanic. That Rocco guy I just can't really speak highly enough about, he is great. Spool is in line with the turbo size, but with the manifold design (one of the best top mount twin scroll's I've seen) and EFR everyone was hoping for more, there may still be more to have time will tell. I know the supra community lags with this particular setup, but it's still a very capable turbo and should keep the stock block happy at high power. Also, I don't really care about boost I care about power, some setups make great power with less boost. This one is only like 50tq behind a typical 6466 twin scroll dyno below 5,000 rpm. And on the street it spools around 800rpm faster than the dyno.
The car was running well at first, had some boost control issues initially that were resolved quickly. It was firing on all 6 great and made just under 800 on a messy pull that misfired the first or second run, after that it seemed to be unhappy on cyl 4. It wasn't overly concerning, they checked everything, just annoying more than anything. Only real "issues" on the dyno were the PI needed some adjustment but they didn't have a way to flash the controller, and the WGDC was maxing out but boost was not increasing. This could point to any number of things that have to do with spool and the peak power obtained, but I don't like to guess.
Here's a log and a snapshot, don't remember which run this was, but most of them were very similar as it was tuning, not just power runs upping boost.
Link to one of the logs bcuz not EMP tuning https://datazap.me/u/v8bait/post-r8-coil-swap?log=0&data=3-7-8-9-10-11-12-19-30&solo=30&zoom=41-108
How is the timing one of them? Its only pulling in #4. If that is killing all the power, why is a set of $2999 turbos, with a single barrel, and simple upgraded making 615/650 on 25 psi pulling 4-9 degrees of timing in #4 every pull? You have to get pulls across to the board to really kill power, yes its costing him a little power, but not enough to put him over 800WHP. For the size turbo he has on the car, and upgrades he has done, power output is not where it should be. Point blankWell I'm pretty sure his goal was 800+. It just didn't get there for a couple reasons, the timing is one of them.
Let me know when transient response is helping you in a race in an AT or proper trans that doesn't drop spool between shifts. If you have a manual sure its great, but for a 950hp turbo, this showing is not up to par for the platform, transient response be damned.The transient response difference does change the game. Good EFR setups don't have "terrible spool" for a start. When spirited driving, it's not like you're constantly loading up the engine from low RPM. Yes, the EFRs do have bigger turbines than what other turbos run for similar size compressors which does slightly increase boost threshold but that's a small price to pay as the turbine is hugely lighter and the larger diameter gives the air more leverage on the shaft. Both of those things help transient response a lot. Also the larger diameter turbine wheel means lower back pressure too.
In summary, give me better transient response over better boost threshold any day. When you're driving a car in an enjoyable manner, you're generally keeping it above the boost threshold anyway but you're constantly making transient changes.
Spoke to you personally, and you said power, and spool were disappointing for the setup. Now you are saying its not. Ok. Yes I take boost from the manifold where it should be taken. Not the charge pipe, where boost is inflated, and the MHD scaling is still not right. My point was, and is. For how much work he has done to the car, turbo set up etc. Power level is disappointing. If people want to argue it isn’t. That’s fine. Different strokes
As for the guy trying to tell me what companies quote compressor wheels dimensions at. Ok, GTX2867, GTX3582, EFR 9180, the list could go on, and on, and on. The ONLY company that quotes inducer size is PTE. Why is that, because they got sued by Garrett back in the day for literally ripping off their entire line up. To help make it look like they were not the same turbos, PTE started naming their turbos based on the inducer size. So they Garret GT3582 was no longer a GT3582, it was a PTE6262 based on the 62mm turbine exducer, and 61mm compressor inducer. Get your facts straight before just regurgitating garbage. The ONLY company to use inducer dimensions is PTE, for obvious reasons.
Don't mind Tony. This is about the only N54 forum left he still isn't banned yet. Just ignore his BS.
someone mentioned earlier about the CES manifold - it's unlikely this will be sold as a stand alone piece.
looking at north of $6.5k for their kit, when/if it comes to fruition.
I hope they do - but it’ll be too late for me. I reached out to CES last week and asked this same question, which is why I believe they’ll sell only the full kit for a while.Oh I think they will, just not initially. I was told approximately $1400.
