Hey guys,
long time lurker, first time poster here. I have a 07 with 19Ts tuned by Doc Vu. Everything has been great for about a year and a half, but I am running into a super weird issue now where intermittently I will lose majority/all boost. The tune targets at most 20psi, and I easily hit that mark, usually even peaking a little bit over, but now that it's gotten warmer (and it gets worse the hotter it gets) I lose all boost.
What I've noticed:
What I've noticed:
- Happens more frequently the warmer it is
- Happens while accelerating
- The WGDC on the logs doesn't change
- The audible blow off gets quiet (I have an HKS BOV)
- The car builds at most 8-10psi after the issue starts.
- Restarting the car while driving does NOT solve the issue.
- Turning the car off and coming back 30 min later returns everything to normal.
- Smoke testing the system shows a small leak near the outlets (however it has been like this since basically the beginning)
- No other leaks are found.
- Only existing issue on the car is a post cat O2 sensor, that occasionally throws a signal code. (This causes the Cilc to happen quite frequently, perhaps it's better to just disconnect the sensor completely
- One time while driving and logging at the same time I glenced at the boost mean and notice it drop from 18 to 3 back to 18. Indicating that maybe something got stuck leaked out and then worked again?
- Boost solenoid (since it is intermittent and it's basically the only electronic part of the whole equation)
- BOV sticking/leaking? (not sure how to diagnose this, it doesn't seem to leak in idle, but perhaps under boost?)
- I can't imagine it being the actuator arm because it's intermittent and then goes back to working completely fine.
