Hi all - as just a general question, how would I show my vehicle as having all readiness indicators OK for smog testing in Cali?
I assumed using MHD with "Flash back to stock" pictured below would work (provided an have a DP fix installed) but the car wont run properly.
I believe its because the stock flash option doesnt take into account the 3.5bar tmap sensor I have installed. Itll idle, but cant accelerate with cutting off. Eventually the overboost warning message comes on ~2k rpms and then it can sort of run
Instead, am I supposed to use the "Flash stage 0 (stock power) option and then from there select 3.5Tmap and OEM/catted DPs?
Thanks!
Thanks!
