All, I'm in the process of setting up my inlets a little different than usual. On the rear turbo I plan to use a silicone inlet, but with the stock type air filter/airbox, with cold air duct. On the front turbo, I will be running a relocated inlet type (silicone inlet as well). Coolant tank is in stock location, and the vacuum cannisters have been relocated to engine left.
Anyone ever tried this?
Thoughts were the front is easy.... the rear would maintain the cold air inlet all that kind of thing, but also while keeping losses low (flow through airbox would be half of stock).
Thoughts?
ETA: front turbo recirc valve will return to airbox in position where front turbo intake was. No recirc to front turbo, rear turbo recirc circuit is as stock.
Thoughts?
