These complete turbo charger unit was removed from my personal 3/2014 535i at 20,880 miles.
It is a super clean take off unit, no rust, no corrosion, no oil consumption. Axial play on the shaft is within spec // as new.
This has got to be the cleanest, lowest mileage, highest quality used turbo on available today. Again it was removed from a personal vehicle and it has an established vehicle history with the seller!
Unit was removed to install a larger Pure Stage 2 turbocharger. This unit is priced below what Pure's core charge is, so its a great way to save some money on a core charge up front, have no down time, and then flip your turbo afterwards... or as a direct install turbo to replace a higher mileage unit that is aging, burning oil etc.
Waste gate actuator and bypass valve are not included. What is pictured is what you will receive.
11 65 7 583 908
TURBO CHARGER
Part 11657583908 was found on the following vehicles:
5' F07 GT (09/2008 — 06/2013)
5' F07 GT LCI (08/2012 — 05/2016)
5' F10 (01/2009 — 06/2013)
5' F10 LCI (08/2012 — 05/2016)
5' F11 (02/2009 — 06/2013)
5' F11 LCI (02/2013 — 05/2016)
5' F18 (08/2009 — 07/2013)
6' F12 (10/2009 — 02/2015)
6' F13 (04/2010 — 02/2015)
$650 shipped in the continental USA.
11 65 7 583 908
TURBO CHARGER
