I am selling my 2011 335Is. 22,000 dollars OBO!!!!!. It is Alpine white. Interior is Black Dakota Leather. Vehicle production date was 12/10. My best friend purchased the car. I am the second owner. Turbos and valve cover were replaced 11/2016 @ 30,000 miles. Current mileage is 54,805 miles.
I only use factory oil and filter. Replaced every 5-700 miles.
Vehicle options: Comfort access, Premium Package, Harmon Kardon surround sound, and NO Moonroof, NO NAVI.
List of Mods:
- Front and rear Ground Control Coil over kit, with M3 Control arms rear. (I rebuild front coil overs 1 year ago).
- Front Camber and caster plates.
- Breyton Race GTS wheels. 18X8.5
- ESS Flash tuning. I have the handheld. You can go back to stock any time
- Magnaflow exhaust system. I will also give you the stock exhaust.
- AR Design down pipes. I have the stock down pipes also.
- Upgraded front mount intercooler. I don’t remember the brand.
- Upgraded all charge pipes with clamps. I don’t remember brand
- Upgrade blow off valves. I don’t remember the brand.
- K and N Air filter.
- Steel braided brake lines. No factory brake fluid.
- Cross drilled slotted rotors front and rear.
- Hawk HPplus brake pads. I have a set of factory pads and also
- Tires are over 60%. Michelin Pilot super sport tires.
- M-Factory LSD diff. upgraded 7/2019
- Vehicle has had been coded. The normal coding like, mirrors, turn signal, Rear diff stuff, windows, etc.
Maintenance:
- Spark plugs and coil were replaced about 1 year ago.
- Engine oil was replaced 4,000 mile ago.
- DCT transmission fluid and Rear diff fluid was replaced 7/2019
- Drivers seat cushion was replaced almost 2 years ago
- Air filter was cleaned a month ago
Vehicle is located in SoCal California. Zip code is 90650.
Please PM and I will give you my number.
I will not ship car but I am whiling to meet up to 2 hours away.
Here are some pictures of the car 6/28/20. https://photos.app.goo.gl/HJQ98fPRMEzB7mVx8
If you want to view more pictures just PM and I will send them.
Final notes: There are no issues with my car. I have a scanner. We can scan car before and after test drive. Engine, transmission, brakes etc. Work like new.
I don’t have any HP numbers but it is fast.
I was asked to provide a DTC report. Which is a DMV title check.
Here you go.
https://www.dmvtitlecheck.com/report...KG1C57BE618081
The reason I am selling is to upgrade to F80 M3. The used car price has dropped now that the G20 is coming.
List of Mods:
Maintenance:
Here you go.
