Fixing my biggest complaint with my 335i, proper trans tuning now available
typedRew
412
221
2009 335i xDrive
The first time I drove my car, I hated how it shifted. I got xhp, I hated how it shifted.
I couldn't figure out why this car, seemingly built well and having the ability to be tuned so much, would have such piss poor feeling transmission shifts.
I couldn't understand why when I drove my car it felt like it was being shifted by someone learning the drive a manual, with long pauses in between gears, whether partial throttle or full but way worse WOT.
I thought for sure someone out there had a solution to fix how poorly this thing went through the gears. Nope, engine tuners just tune around it and its accepted that you just accelerate while pausing for each shift. I couldn't understand it. Every turbo car I've ever driven has been complimented by an automatic box because it flows power through the shift, its one of the biggest benefits to having an automatic turbo car. But no, not us, cut all that power off at the knees every time it clicks up. I hate it.
I finally found someone who is big into the 335/X5 diesel market, Rod Sutphin @ www.sutphintuning.com or you can contact him on facebook through the Suphin Tuning page. He claims he can make the ZF 6 speed auto perform how I want. But he only tuned diesels and apparently, the gas cars are completely different. Lots of diesel guys say his tune transforms their car, I want in.
I begged the guy, I asked him a few times this year if he would consider working with me to try and get the tune ironed out for these cars. He finally caved and said he would give it a shot. He sent me a base file and here we are after countless revisions later with something thats damn near perfect and ready for consumption. He wasn't wrong, its a completely different tuning process from the diesel cars. We went through a lot getting this thing right. Believe me when i say, if you aren't happy with something, he will work with you to make it right. It is not a 'canned' tune, he will customize it to your liking and to your specific vehicle setup.
He even found some never before touched tables in the engine tune that helps cohesively blend the trans tune and engine tune even further. But if you're using a locked tune like MHD OTS or similar, unfortunately he can't taylor it perfectly for you, but he can get you damn close. Luckily my RFP OTS and my new RFP custom file are unlocked so he was able to tweak it a little bit to make it do what he wants, so between that and his absolutely fantastic transmission tune, it is damn near perfect, basically exactly what I wanted this car to do the first time I drove it, what I expected it to do, it now does.
Instead of it pulling sometimes -25 degrees(!!!!!!) every shift up, it pulls nothing, it just flows into the next gear with no hint of lost power and the shifts click of firmly without complaint or any jerkiness. Its just smooth constant power, like youd expect in a turbo auto car(just not the platform, until now).
Example of normal shift timing loss with mhd ots and xhp stage 3:
https://datazap.me/u/typedrew/v5-e40-random?log=0&data=3-22-27
Notice over 20 degrees between gears is the norm.
Now, with my custom transmission tune, most current revision. Which still pulls a minor amount of timing 4-5, but nothing on every other gear; 1-2-3-4. We are working on 5th gear at the moment, but it is a complete world of difference compared to before.
https://datazap.me/u/typedrew/14-mile-rfp-e50-v7-rev36?log=0&data=3-22-26
It drops down to the appropriate timing for the given rpm in the next gear, but does not pull timing(or power in any other way) between shifts. You'll notice the largest dip is when it clicks 5th, which looks large but its only -2 degrees. A major improvement over before and thats after most people 1/4 mile run anyway, so its not a huge deal. But we will be working to eliminate it altogether over time.
This isn't even saying how much better it is driving every day, the partial throttle might be even better than WOT. If you don't have open intake or loud exhaust, you won't even notice it shifting. Heavy pedal but not wot almost feels like a cvt, smooth and rolling through the power.
Video of my car running through the gears(for folks with good ears, you can actually hear the distinct difference between every other gear and the 4-5 where a minor amount of timing is pulled instead of carried, again, he is working on that);
He has been tuning my car and a dozen others during this time with one of them making almost 750whp, no complaints only praise. Even if you don't mind the way these cars shift, i still think once you experience this, you won't want to go back. If anyone wants a ride, i'm in SE Michigan and willing to let you try it.
All this being said, his tune, just like XHP will bring out any maintenance or worn parts you may need to service or replace. My car has 170k miles almost with no known service history and has tolerated this process and this tune perfectly, but that doesn't mean it will be the same for anybody. Mods and tunes are not a replacement for proper maintenance or service, so make sure the car is up to the task or at the very least, be ready for if it isn't and you need to do some work to get it right. Most cars could do with a fluid, filter and solenoid change given their age at this point even stock, so just keep that in mind for in the future.
EDIT: this combination went 11.61 @ 117.5 last night on somewhat wet cold roads. (intercooler, e50 tune, sutphin trans tune, CP and fuel pump)
typedRew
412
221
2009 335i xDrive
Very nice write up Drew! Glad it is running well. Let's put some newer Turbos is that thing and take her to run some 1/4 mile times.
You know i'm down for that. I need new turbos so bad.
Hell, I just updated my best time last night;
1and1
65
35
Tally, FL
Have I missed some new revelation on the post shift timing "corrections"?? I thought that was what everybody would be talking about, not just the custom shift map he had made...
typedRew
412
221
2009 335i xDrive
The timing being dropped every shift is completely separate from getting a timing correction after a shift. One is a planned event in the DME that can be tuned through the engine tune and trans tune combined, the other is just the DME correcting a knock event.
You can get both the timing drop from the shift and a timing correction at the same time.
example below
Reactions: V8bait
Milan
413
241
jebi se
your mom
Love seeing these threads and then I look at the car and it's some FBO car that doesn't make dick for power. Come back and talk to me about how good your tuner is when your car has more than an intake a few gallons of E85 as mods lol
  • Dumb
Reactions: scrllock
V8bait
505
785
Texas
That first picture the engine tune has most of the factory ignition timing and torque management features enabled, they are there to allow the trans to fully shift and prevent slip, minimizing wear. The second picture you've simply disabled those flags in the tune. That's fine in most cases and more performance oriented, it's how I tune these cars generally, but realize there is a reason for those very brief dips. On cars pushing the trans limits, utilizing the timing and torque management can be the difference between completing the shift into 5th and winning a race, vs the trans being unable to complete the shift and your motor bouncing off the rev limiter, which can damage motors. You can only really get away with this trick until around 550-600 torque.
You are absolutely right about the two isolated kinds of events, the planned one and the knock one. There's also a third, an interventional event when you get boost spikes at shift which can also can cause ignition intervention. Those can also be pretty common on aggressive maps.
Glad to see someone digging into the trans tune though, I agree 100% there's room for improvement on that side. The way I fixed it was by adding a third pedal, problem solved!
typedRew
412
221
2009 335i xDrive
It went 11.6 @ 117 with my shit for mods. So, i'm fine with having no power and just using it all as best I can. I'll do more to the car as I can afford to, maybe then you'll take me seriously? lmao
Would you rather only people with 10k in mods went low 12s or tried to do something good for the platform?
And to be fair, I dont have a fucking air intake either, or FBO. Stock downpipes, stock airbox. 170k miles as well, so since I didn't buy a low mileage car, I bet i don't get an opinion either right?
The guy tuning my car tunes 700hp diesel 335s and he is also tuning a 750whp N54 at the moment, so its proven to work, not just on my car.
But good job dismissing it just because my pile of shit beater doesn't fit your standards, enjoy XHP OTS tunes all you want. :cool:
typedRew
412
221
2009 335i xDrive
You posted this on E90 as well but then deleted it, ill quote my comment to you here;
We have ran with adjustments only to the engine tune and brought timing loss on shifts down to about -15 degrees at best. It will 100% not do what we are asking it to without touching the transmission tuning file, removing those flags only reduces the timing drop marginally.
Trust me, I have about 65 tuning revisions showing its not 'just disabling flags and removing torque management'. The approach to this has been seriously in depth, more than I bargained for really when i asked for help, but its been enlightening.
The first tune is a standard mhd file and standard xhp stage 3 file on my car, basically what most people will be running as an example.
And yes, its all done with caution. Rod knows the limits of these cars very well, he is versed in the mechanical side deeply and knows what changes to make and what will cause what problems. One of the reasons he has left the E clutch on the 4-5 shift with still having a minor timing pull is because of this knowledge.
The diesel cars he is used to make upwards of 700lb ft with turbos alone and he keeps those 6HPs in one piece with his tuning, so he knows how to work around power levels.
From what we can tell, using the hard timing cut and torque management actually presents much harder wear on components than what we are doing now.
But yeah adding the third pedal does sort of just fix the glitch, lol If my back would let me drive manual anymore, i'd do it to.
Reactions: V8bait
V8bait
505
785
Texas
Yeah I dislike that site so when I saw posted here I just copy pasted.
6hp in diesel's is actually a completely different trans.
Otherwise good to know there's room for improving the trans flash. I feel we're still pretty lucky to have gotten xHP in the community with the public xdf made available, I can't stress how big that was, just for reasons like this.
typedRew
412
221
2009 335i xDrive
Absolutely agree, XHP being in the game is huge and yes I know the trans is different. But the idea is similar and weaknesses are nearly identical despite their differences.
And there is still room to improve this flash, hes not one to sit back and stew. He will keep trying to improve it no doubt, just like he does with the diesels.
Milan
413
241
jebi se
your mom
It's not about how much money you have spent in mods, it's about the fact that you haven't really hit any limiters that come from doubling and tripling the power on these cars.
Other than the fact that it feels better to you, you aren't really documenting a gain that I can see. How many tunes/tuners have you tried? Just seems to me like you got your first custom tune ever and seem surprised that it's better than running something off the shelf lol
  • Wow
Reactions: typedRew
typedRew
412
221
2009 335i xDrive
Did you even read the post? I mean, clearly you didn't so dont bother answering. We aren't even talking about engine tuners holy shit.
Nobody tunes the transmission, nobody. and thats what this is about. As clearly stated in my post and datalogs, the proof is right there. Rod Sutphin is the only one aside from XHP. And like I said, he's tuned and is currently tuning plenty of cars that make double the power as me, so hes already got experience there. But that doesn't really matter since you apparently thought I posted about engine tuners.
Milan
413
241
jebi se
your mom
So this guy tunes the TCU? What software did you use to upload that "tune" to your car? I am confused because I don't think you understand what you are even talking about.
What I think you are trying to say:
Your tuner control the way the DME interacts with the TCU to control shift quality. The changes are made in your bin file and you are flashing with MHD
What your post/post title implies:
Stock transmission tune was trash, xHP was also trash. This diesel guy pops up out of the wood work and is the second coming for the 6AT?
Can you elaborate on what "nobody tunes the transmission" means?
typedRew
412
221
2009 335i xDrive
Dude, are you drunk? Did you even attempt to read my post? It lays it out there pretty clearly whats going on.
I have been working for months getting my transmission tune ironed out and you think I don't know what i'm talking about? No he isn't using MHD. He has however modified my open tuning files and made the trans and engine tunes cooperate a bit better. We use XHP to flash the trans tunes. He builds a map from the factory XDF, nothing from XHP ots mapping exists in the wild, so this is all from scratch, just like his diesel tunes.
We literally have gone over every single complaint or detail of what I like and what didn't like, what we were trying to do, what worked and what didnt. For months and 60+ revisions.
And no, I searched him out(as i said IN THE FIRST POST)and asked him to try tuning the gas cars since he was held in such high regard in the diesel community and he gave it shot. He didn't just appear out of nowhere and I drank the kool aid because it was pretty colors. The results spoke for themselves in his other work and I wanted in.
Not only that, but after he started tuning my car, in order to better serve, he BOUGHT his own E90 xdrive 335i so he could make progress on his own side without just me telling him over the phone what worked and what didnt. And he just ordered a set of VTT Game Changers for it, so he will be making some jam here soon so hopefully he can make enough power to get your attention.
Elaborate on nobody tunes the transmission? Okay. Nobody does. XHP offers off the shelf files, Stages 1, 2 and 3. Thats it. Nobody in offers custom tuning.
It would be like mhd ots maps being the only thing available for your engine with no tuners offering customization for mods, thats the one size fits all approach to trans tuning currently. And thats what makes Sutphin different, and why I made this post. Because literally, its not been done before.,
Milan
413
241
jebi se
your mom
So you ARE using xHP.
My issue is with the fact that in the first post you seem dismissive of xHP but they literally provided you/your tuner to have access to your transmission in the first place. Why does xHP offer the ability to flash custom maps if "nobody tunes transmissions"
scrllock
267
153
2011 335xi
Quit trolling dude, it's silly. The issue he has is with XHP ots maps, not the app itself, it's a clear difference to everyone reading this except you.
I'm in the SE MI area at least once a week, would love to compare the shift feel. Not a fan of RFP tunes, but I've heard of sutphin, cool you got him to do this.
typedRew
412
221
2009 335i xDrive
Obviously i'm using XHP, i'm flashing the transmission. I was dismissive of XHP in the post because I dislike the way their tune drives, it was one of the things I hate most about the car. But that has to do with the fact that its identical to how the car drives stock. So its the same idea just modified.
I can not like MHD tunes and still flash custom through mhd.
