I made a post about fire extinguishers before in the E9X section regarding under seat extinguishers but lets be honest, that is unlikely to save your vehicle from an engine fire. It is much more likely that you'll pull over after you see flames coming from the engine bay and by the time you are pulled over and get out, the heat will probably be too much to even open the hood not to mention get it extinguished in time.
One of my biggest fears is losing the car to a fire, there is no bigger total loss than that. When we consider the amount of money we've put into these machines, it almost seems unwise to not take some precautions against preventing complete losses such as this where you stand helplessly while your car slowly burns to the ground.
I have absolutely no experience with this, but has anyone considered installing a fire suppression system with nozzles into the engine bay? I know there are many different types of chemicals/compounds that can be used which are safe or not safe on electrical components, however I'd like to know if anyone has any experience or thoughts on such a system?
It seems like you can buy a decent setup at various places like BW or Jegs for under $500. If it is feasible, it seems like a reasonable expense?
Kit Includes:
Skip to 5:30
Kit Includes:
- 5lb Bottle
- Bottle Head
- Installation Mounts & Clamps
- 8' Cut-To-Fit Pull Cable
- (2) 2-Port (or 120°) Nozzles
- (1) 6-port (or 360°) Nozzle
- All Necessary Fittings
- 12.500 ft. Of Tubing
Skip to 5:30
